Help, on trip, Brake light problems
Old Jul 29, 2012 | 04:19 PM
mrad's Avatar
mrad
Today while coming down the pikes peak hiway we were notified at a brake check point station that both break lights were out. Upon further inspection I realized that only the left brake light above the cargo doors was working. Does this sound like lights going on the blink a once, or a relay issue? We checked the brake on off switch fuse and it appeared to be good, any suggestions on what to look for at the camp ground.
Old Jul 29, 2012 | 06:20 PM
mrad's Avatar
mrad
Stopped at an auto parts store and replace two burned-out bulbs above the cargo doors. Brake lights still do not work. Replaced both brake lights. Have running lights and blinkers. When I got back to the campground, I hooked up to the camper in the camper doesn't have brake lights either. I'll look for a mechanic in the morning. Otherwise let's meet stuck in colorado springs for a while. Anyone have any ideas?
Old Jul 29, 2012 | 07:13 PM
Hemmi06's Avatar
Hemmi06
Turn signal switch... Check for buggered wires. I could make my brake lights work when this happened to me by moving the tilt steering. I had a wire shorting out...
Old Jul 29, 2012 | 07:40 PM
mrad's Avatar
mrad
Hemmi06,
Thanks. Gave it a try but no luck.
Old Jul 29, 2012 | 08:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
Switch on the brake pedal itself?
Old Jul 29, 2012 | 08:36 PM
mrad's Avatar
mrad
Would the lights above the cargo doors light of this was the problem?
Advanced auto parts guys thought I may have a cut line.
I have no idea. Trying to decide between steelership and local guy a block from campground
Old Jul 29, 2012 | 11:20 PM
Hemmi06's Avatar
Hemmi06
Yes the third brake light works with this issue. Turn Signal Switch or a wire in sterring colum...
Old Jul 30, 2012 | 01:42 PM
mrad's Avatar
mrad
Brought the X into a local garage. They said multiple switches failed. The one on the brake pedal was one another one. Don't remember what he called it. I"ll be about $400 into it with parts labor and diagnostic. Oh the fun of traveling with a travel trailer.
1997fordf350
Jul 8, 2013 01:54 PM
confederate_mudder
Electrical Systems/Wiring
Apr 9, 2007 01:29 PM
im_pop69
Feb 6, 2006 03:38 PM
Bob47
Aerostar
Jan 7, 2004 08:14 PM
Runner70
Jun 14, 2003 06:23 AM
