Brake lights
Old Jul 8, 2013 | 08:55 AM
1997fordf350's Avatar
1997fordf350
Brake lights
Hi guys. I'm having trouble with my brake lights. The turn signals work and normal lights work. The third brake light works too. Any thoughts.
Thanks.
Old Jul 8, 2013 | 09:40 AM
dixie460's Avatar
dixie460
Brake light switch? Without a schematic I can't tell, but if the flashers work (which use the same filaments as the brake lights) then your bulbs and everything else common to both are in good shape.
Old Jul 8, 2013 | 11:09 AM
1997fordf350
Where that at. Flashers work
Old Jul 8, 2013 | 11:21 AM
White 97 xlt's Avatar
White 97 xlt
Do your 4 way flashers work?
If not, make sure the switch is in the DOWN position, up is on and it kills the brake lights to everything BUT the high mounted stop light.. (3rd brake light)
Now if this cures the brake lights check out the flasher unit on the back side of the fuse panel (up under the dash), (the one on the front is for turn signals) there is a good chance the flasher unit has gone bad and the hazards (4 ways) have been turned on at some point.
Old Jul 8, 2013 | 01:54 PM
1997fordf350
Ok messed around with the wires an stuff. They are working now but don know for how long
mixerdrvr
May 26, 2013 09:04 PM
breadstick
13
Mar 19, 2012 08:32 PM
psoff
1997 - 2003 F150
Sep 22, 2007 11:33 PM
Bob47
Aerostar
Jan 7, 2004 08:14 PM
Runner70
Jun 14, 2003 06:23 AM
