My Brake lights on my 1999 ford expidition are not working! The rear turn signal, reverse lights, and emergency flashers are all working properly! Does anyone have any suggestions? Thanks for your help!
I had a Ford Fairlane that had a brake light switch attached to the brake pedal up under the dash that went bad. That's how your brake lights get their power. Also check your fuse panel.
Good luck, hope I shed some light.
