No Blinkers
Old Feb 6, 2006 | 11:43 AM
im_pop69's Avatar
im_pop69
Question No Blinkers
All my lights are working on my F250 Heavy Duty Desil. But for some reason the blinkers are not working. The bulbs are good. Just put in new flasher & fuse. Can't figure out what is going on. Any suggestions?
Old Feb 6, 2006 | 01:00 PM
balddave's Avatar
balddave
Sounds like your multifunction switch is out, or you have a bad ground for the circuit.
Check to see of your brake lights are out too. The rear brake lights I believe go through the multifunction switch. The high mount brake light(dedicated brake light) does not. If you have the dedicated brake light and no other brake lights , It's one of the the problems mentioned.
Most likely the switch if I had to pick one.
Old Feb 6, 2006 | 03:38 PM
Franklin2's Avatar
Franklin2
Yes, check your brake lights, and tell us what year you have.
