Cool tachometer ID
Old Jul 28, 2012 | 10:15 PM
Ford_Six's Avatar
Ford_Six
Cool tachometer ID
I had this old tachometer given to me this weekend, and would like to find out some info on it. It's made by GE, and I believe came from an aircraft as there are some markings on a sticker that has a pair of wings with 174 in the center and either JAX or OAX under it. That same sticker also says "ready for issue 17 JUN 1947".
It just looks cool-
ID tag:
It's odd because most aircraft tachs I can find are a single sweep 3500rpm gauge, this is the first I have seen that is a multi-rotation with a smaller dial for the thousands. I was thinking of making a nice brushed aluminum mount for it with maybe some circuitry and a battery to actuate it, with a dial to vary the rpm indicated as a desk toy.
All the searches I have done on the part numbers have come up with weird stuff, no pictures and some references to a Kollsmann indicator but nothing about a GE one.
Does anyone have info on this tach, specifically what sort of plane it would have come from?
Old Jul 29, 2012 | 01:13 AM
ford2go's Avatar
ford2go
Negative results in my brief searches, which were surely less thorough than yours.
But, I wonder if you might try to find some arcraft cockpit pics from that era. I've seen some sites that offer good ones, but I can't recall right now. (Maybe the Wright Patterson AF museum and others like that).
JAX is quite possibly Jacksonville, which has a Navy base if I have my facts straight.
The other thought is that since they've expanded the 100's scale, RPM might be critical. I saw a lot of stuff about motor generators -- sometimes used to generate 50Hz power. It could be that it's from something like that where they need the frequency to be exact.
Good Luck,
hj
Old Jul 29, 2012 | 04:58 PM
helifixer's Avatar
helifixer
the second line is the customer part number (r-88-1-2385-100) the dash 100 is the first model of this tach. so any upgrades would have been -101 or -102
the part number layout seems to come up as lockheed part number sequence. but my internet is slower than dial up right now so I am not having any luck searching right now
Old Jul 30, 2012 | 08:32 PM
Ford_Six's Avatar
Ford_Six
Good Luck,
hj
I thought along those lines, but most generator systems I can find info on had a balancing governor-style system that would regulate them at 59-61hz.
This may have been from an aircraft that used a variable pitch prop, where rpm needed to be fairly constant and the pitch changed.
It's hard to tell given the interchangeability of Mil-spec stuff. I just thought it'd be cool to have some sort of a backstory to this piece.
shorebird
Oct 12, 2009 01:54 PM
Bdox
Apr 23, 2007 06:47 AM
longview1
Aug 5, 2005 08:09 AM
TheWiz427
26
Aug 9, 2003 04:16 PM
