coil spring sag
Old Jun 9, 2003 | 03:35 AM
Pkupman82's Avatar
Pkupman82
coil spring sag
First question: Is the installation of the shims basically the same for my 4x4 as it is with your 4x2?
Second question: Would it be easier for me to install the coil springs and then take the truck to a shop to have the shims installed?
Old Jun 9, 2003 | 10:35 AM
FatzFord's Avatar
FatzFord
coil spring sag
hrmm ..the books shows your 84 f150 4x4 with front coil springs and the only other shot of the spindle is the same as my truck. it also looks like there is an adjustment shim in the lower ball joint. Id install the springs and then take it down and have a professional align it. I'd ask a shop that does lifts for a recomendation for the alignment because he will have to replace the shim if your springs lift the truck within the 2" limit. Have fun..
Old Jun 9, 2003 | 11:46 AM
kohlerjd110's Avatar
kohlerjd110
coil spring sag
my truck has front ling pins and now the camber is not right the bottom of the tire is in and the top is out
Old Jun 9, 2003 | 03:38 PM
FatzFord's Avatar
FatzFord
coil spring sag
looks like your talking about spindle pins right? I see that your 84 has them. The book says that the camber is pre-set so if youv'e lifted the truck it would stand to reason that the camber is wacked out. You need new spindles to correct that no matter how far you've lifted the front end. The 82 still has a camber adapter. My book stops at 86 so I can't say how your 87 is configured..
Old Jun 9, 2003 | 03:47 PM
FatzFord's Avatar
FatzFord
coil spring sag
Of course the spindle pin bushings could be warn to the point that your camber is out..;-)
Old Jun 10, 2003 | 03:30 AM
Pkupman82's Avatar
Pkupman82
coil spring sag
Sounds good thanx FatzFord!
Old Jun 11, 2003 | 11:45 AM
kohlerjd110
coil spring sag
the king pins and bushings are new. I need to lower the inside end of the i beam so the camber will go back to normal. does any one know where i can get theses.
hhowell1990
18
Nov 30, 2014 10:24 AM
marcograms
Jul 15, 2010 09:41 PM
redrush40
Oct 28, 2005 06:28 PM
GeneStoner
33
Jul 19, 2005 11:04 PM
