Front end sag?
Old Nov 20, 2014 | 10:02 PM
hhowell1990's Avatar
hhowell1990
Front end sag?
My truck has what i believe to be a fairly bad case of front end sag, only about 3-4 inches between the top of the tire and the bottom of the wheel well, i want to even that out so the truck sits level. I'm looking at either getting a set of firestone air helper springs or sdtrucksprings.com HD coil springs. can anybody tell me the pros/cons of either of these setups?
Old Nov 21, 2014 | 11:05 AM
montanasteve's Avatar
montanasteve
Before getting my slide-in camper, I got one of the add-a-leaf front "leveling" kits. I believe mine was from Tuff Country. They sell the same kit for the F250/350's, and mine overshot level by about an inch. I need to get the F350 rear axle block spacers at some point, which would bring the rear up 2". As for the suspension in the front, I love the stiffer ride with the leveling kit. Much better steering on the road when I have the camper in, or when carrying/towing a load. The kit was less than $300, I believe. I also added the air bags for the rear for load carrying. As far as air kits for the front, I'm not so sure about that. A coil-over front might be great, but again, I'd want to drive one first. The add-a-leaf kit is straightforward and simple - you'll get more height, a stiffer ride, and that's it. My favorite alignment shop was happy to install it and do the alignment afterwards.
Old Nov 21, 2014 | 11:08 AM
binuya's Avatar
binuya
Sounds like the OP has 2 wheel drive. Coil front suspension.
Old Nov 21, 2014 | 11:12 AM
montanasteve
Oops, yep, that makes sense. Nobody 'round here has a 2wd, so that never crossed my mind!
Old Nov 21, 2014 | 11:16 AM
binuya's Avatar
binuya
Yep. Took me a minute too when I first read what he wanted to do.
Old Nov 21, 2014 | 11:58 AM
Franko72's Avatar
Franko72
Molon Labe
You could always add a 2" leveling kit under the front springs.
I found mine on Ebay, can't remember the brand but it's all aluminum.
Before
After
Old Nov 21, 2014 | 02:55 PM
gradyc's Avatar
gradyc
wellhead
X2 on what Franko said. Also ordered the 2" aluminum spring blocks on E-bay. Worked great.
Old Nov 21, 2014 | 06:53 PM
hhowell1990
that's correct mind is 2wd. I talked to a buddy that's got bags on the front of his 2wd 2500 HD and he said it raised his front end 2-3 inches I think I'm going with bags since they're cheaper
Old Nov 21, 2014 | 06:55 PM
hhowell1990
Before
After
thanks for the pics that's about how much mine is sagging and that's how much I want to pick up the front end
Old Nov 21, 2014 | 07:57 PM
hotrodfeguy's Avatar
hotrodfeguy
http://www.summitracing.com/parts/tf...350-super-duty
Here is a pic of the results of the ad a leaf. I was more than happy with the $175
http://i146.photobucket.com/albums/r...ps2c190fb1.jpg
Old Nov 21, 2014 | 08:07 PM
F350-6's Avatar
F350-6
I tried front end bags on mine when the coil springs got tired. Won't ever do it again. Bought replacement springs from Ford and it still seemed to sag more than it should.
Finally ended up with 2" aluminum spacers under the new springs to get it back right again. If I had to do it all over again, I would have let the local spring shop build me a new set of front coils.
Proper way to measure wear isn't at the fender but where the bump stop is.
Supposed to be way more than that. Those were my old wore out springs.
This is when I did mine. https://www.ford-trucks.com/forums/7...uspension.html
Of course after I went with the leveling kit I had some shock issues since I drive on roads rough enough that the shocks actually do some decent travel. https://www.ford-trucks.com/forums/1...ck-travel.html
(ended up with bolt extenders on the shocks).
Old Nov 21, 2014 | 09:33 PM
hhowell1990
Thanks for posting that thread, after that thread and the before/after pics from Frank I'm definitely going with blocks for my front end.
Old Nov 22, 2014 | 04:07 AM
Franko72's Avatar
Franko72
Molon Labe
Hey Hunter, check out the thread of when Roland & I installed my leveling kit. It has some info that will help you along the way.
A small amount of grinding may need to be done & you'll need a set of dual axis camber bushings. Any reputable alignment shop will carry them.
I let the shop install em when they aligned my truck.
https://www.ford-trucks.com/forums/1...kit-is-on.html
Old Nov 22, 2014 | 04:49 PM
hhowell1990
Thanks for the info Frank, I just ordered the 2" blocks and want to do front shocks as well when they arrive, do you have any recommendations as far as brand/series?
Old Nov 22, 2014 | 05:56 PM
Franko72's Avatar
Franko72
Molon Labe
I really don't have any favorites. I need new shocks all the way around, so I'm in the same boat.
I have Reflex's on the truck now.
