coil spring sag
Old May 11, 2003 | 05:11 PM
kohlerjd110's Avatar
kohlerjd110
coil spring sag
Is there a good way to fix the coil spring sag on a 82 f-250.Would coil spring out of a 4wd be a litle stiffer? does any know the price on new springs.
Old May 11, 2003 | 06:16 PM
FatzFord's Avatar
FatzFord
coil spring sag
Hmm a new set of springs is the way to go. A 2" bump up would be cool, I got the whole kit for under 200.00 but springs alone are less. Look for superlift.com...
Old May 25, 2003 | 08:58 PM
kohlerjd110
coil spring sag
i traded a friend of mine for a new set of F-350 coils springs. Will theses fit?
Old May 26, 2003 | 08:25 AM
FatzFord's Avatar
FatzFord
coil spring sag
The height is the same and the dimensions are the same you will be ok. If they rise your front end more than 2 " you'll have problems such as camber adjustment as well as pitman arm problems. Measure them against your original springs to see.
Old May 26, 2003 | 06:40 PM
kohlerjd110
coil spring sag
the originals are 15 and 1 half inches and the new ones are 17
Old May 26, 2003 | 10:07 PM
FatzFord's Avatar
FatzFord
coil spring sag
camber shims can be gotten from superlift.com I hope I can say that ;p
Old May 27, 2003 | 09:19 PM
NorthernFord's Avatar
NorthernFord
coil spring sag
I'm just going to make one suggestion, whatever you do, DO NOT get the adjustable camber shims, we have had nothing but problems with them at our shop.
Old May 27, 2003 | 10:47 PM
FatzFord's Avatar
FatzFord
coil spring sag
agreed, I have a set in my truck and will be removing them as soon as I can find someone with the right ones.
Old Jun 5, 2003 | 12:11 PM
kohlerjd110
coil spring sag
it lifted the truck 2 inches
Old Jun 5, 2003 | 01:48 PM
FatzFord's Avatar
FatzFord
coil spring sag
I used a set of springs I got from super lift that were called leveling springs. I had dropped my real end 2" and needed two inches in the front to level out the truck. Surprise was that I got a slight rake and needed the shims to correct camber adjustment.
without any other hardware 2" is about the limit you can go..I guess ;-)
Old Jun 6, 2003 | 11:23 PM
Pkupman82's Avatar
Pkupman82
coil spring sag
Everyone is talking about shims on the TTB frontend. Where do they go, how are they installed, can someone tell me why they just don't include drop down brackets with these leveling kits?
Old Jun 7, 2003 | 08:23 AM
FatzFord's Avatar
FatzFord
coil spring sag
the shims go in the spindle in the upper ball joint. If you crawl under the truck and look up in the upper spindle you will see the hex nut end sticking out of the ball joint hole. I have seen kits that include other adjustment shims for the spindle as well..
Old Jun 8, 2003 | 12:53 AM
Pkupman82's Avatar
Pkupman82
coil spring sag
How difficult are they to install?
Old Jun 8, 2003 | 04:07 AM
FatzFord's Avatar
FatzFord
coil spring sag
well lets put it this way ..If your doing it at all, your axles are in the shop getting the ball joints pressed out because if your going down that far you might as well. I was also rebuilding the steering portion of the front end. I had the guy that would align the thing put the adjusters in for me after I was finished. See my gallery..
Old Jun 8, 2003 | 08:33 AM
FatzFord's Avatar
FatzFord
coil spring sag
but!! if all you want to do is replace them..its a challange
