M5R2
Old Jul 28, 2012 | 12:22 PM
lauxford's Avatar
lauxford
M5R2
i have the M5R2 5 speed in my 95 4x4 its haveing problems and at 60 mph it makes a rumbling sound. what i need to know is should i have it rebilt or is it something i can atemt my self i have moderet skills working on vehicals and also is this even a good transmition or is there something better. b tw i have the 4.9l
Old Jul 28, 2012 | 04:03 PM
882tank's Avatar
882tank
What kind of "problems" are you attributing to the tranny? Is it a bearing whine? Have you checked U-joints, motor mounts, tranny mount?
Old Jul 28, 2012 | 04:11 PM
85e150's Avatar
85e150
It's full of oil, right? ATF?
The Mazda box is ok, and if the ratios work for you, I'd leave it.
Ford also installed the ZF behind the 300 and 351w, so you could bolt one of those in if your trans is bad. It is a heavier trans with a lower first gear. (5.7x vs. 3.9 apprx for your trans)
But first, oil and all the other stuff in the prior post.
R&R of the Mazda isn't terribly hard, but I think you need a press for some bearings and gears.
Old Jul 28, 2012 | 04:21 PM
octaneforce's Avatar
octaneforce
no flaming for spelling corrections? i am surprised. a rear end problem can also make that sort of noise on the highway. but definitely check the tranny fluid before you start tearing things apart. wheel bearings tend to rumble when they go bad, too. there's a lot of other things to look out for as mentioned.
Old Jul 28, 2012 | 04:56 PM
85e150's Avatar
85e150
Hay, hu ar you to tak? Tri using a capitol leter at the star ov you're pare of graphs!
Old Jul 28, 2012 | 04:58 PM
lauxford's Avatar
lauxford
yea i changed all the u joints new tiers but not the oil in the trans ... btw what is the oil i put in it ..... and the rumbl alwys starts at 60 mph every time
Old Jul 28, 2012 | 05:18 PM
85e150's Avatar
85e150
Oil for the M50D is ATF, Mercon V. Others have used Redline, 10w-30 etc:
https://www.ford-trucks.com/forums/3...-for-m5od.html
https://www.ford-trucks.com/forums/5...-for-m5od.html
As for the rumble at 60, do you have it in 3rd, 4th and 5th? Or just in one gear?
If in all three gears, look at your driveshaft and make sure it isn't bent or dinged. Check the wheel and pinion bearings. All should be about the same temp after a drive. If one is really hot compared to the others, you should replace it.
The rumble was there and stayed the same after the u-joint job?
Same with tires?
Old Jul 28, 2012 | 05:31 PM
lauxford's Avatar
lauxford
im in 5th gear at 60 mph when the rumbl starts gets worst faster i go. iv alredy replaced the frount wheel bearings balljoints shocks u joints springs . havent done anything to the rear end and all i can figure is its the transmisstion! ohh and yes same noise is the same *** it was b 4 all the work iv done
Old Jul 28, 2012 | 07:13 PM
carolinaranger90's Avatar
carolinaranger90
When it comes to the rumble/vibration, don't push it too far.
These pictures show what happened to the transmission going 75mph
This was the top of the transmission.
Old Jul 28, 2012 | 07:18 PM
85e150's Avatar
85e150
Just in 5th gear?
Old Jul 28, 2012 | 08:51 PM
lauxford's Avatar
lauxford
yea only 5th gear i chaged the fluied today just to make sure and the rumbl is still there right at 60 mph and up also gets louder when i ride the gear down also its a lil louder when i put the cluch in but always gos away at 60 mph iv replaced alot and only thing that was left is ether the tranmission or maby the transfer case
Old Jul 28, 2012 | 08:53 PM
85e150's Avatar
85e150
Check the TC oil?
Old Jul 29, 2012 | 04:49 AM
lauxford's Avatar
lauxford
yes sr all i can do i gess is ether take it to a expisove shop or try the do your self thing. i can get a press and a slide hamer. also there are diagrams on the net so i am just going to nut up and just the the job slow and neat! if here is any other advice u can give me toat ould be grate
Pigpendirtface1021
Dec 3, 2018 06:20 PM
juice90
1983 - 2012 Ranger & B-Series
May 1, 2012 01:58 AM
pmibach
17
Mar 24, 2012 10:20 PM
fordtruckinsml
Oct 29, 2003 10:17 AM
old timer
21
Jul 3, 2000 02:26 PM
