ignition
Old Jul 27, 2012 | 04:59 PM
montgomeryt13's Avatar
montgomeryt13
Arrow ignition
My 1989 Ford Ranger is having ignition problems i replaced the starter starter sylenoid and ignition switch but i try to connect my positive battery terminal and evenwith my ignition disabled by me still wants to start could this be a faulty ecu or coil pack witch the coil pack is also new?
Old Jul 27, 2012 | 06:03 PM
ctubutis's Avatar
ctubutis
Sounds like you are trying to describe the starter motor wants to begin turning as soon as you hook up the battery?
Disconnect the small red/blue wire from the solenoid (should be on the S terminal) and then try to connect the battery; does the behavior continue?
Disconnecting that wire removes the ignition & neutral safety switches from the scenario, this leaves only the starter solenoid. Could be you have a faulty one right out of the box (happens pretty frequently with Chinese-made solenoids these days) so I'd then put your original solenoid back in place and verify that problem goes away.
Old Jul 27, 2012 | 06:39 PM
montgomeryt13
yep
you were right it was a bad one right out of the box except it was made in mexico thanks for the help we had a spare one off a chevy and hooked it up attached the battery and off it went lost a starter in the process tho
Old Jul 27, 2012 | 07:38 PM
ctubutis's Avatar
ctubutis
Thanks for the update
Old Apr 4, 2014 | 09:10 AM
Danny Watson's Avatar
Danny Watson
I had same problem. I had mixed up the wires to new sol. and fixed problem by simply putting sol. wires on correctly.
Citymorg
Electrical Systems/Wiring
48
Sep 29, 2019 02:41 PM
71mach351
May 18, 2014 02:42 PM
rustygold1
Jul 21, 2013 12:06 AM
78BigBlock09
Mar 30, 2010 02:48 PM
althund
1978 - 1996 Big Bronco
26
Jul 9, 2006 01:11 PM
