Ignition wiring question
Old May 17, 2014 | 04:08 PM
71mach351's Avatar
71mach351
I'm trying to install a new wiring harness and have an ignition question. With the key switch to 'on' I have 12v to the starter solenoid. I have traced it to the ignition wire to the '+' side of the coil. The '-' side of the coil goes to the distributor. When the points are closed I have 12v to the starter solenoid. When they are open, no power to the solenoid. When the key switch is in the start position I have 12 v to the starter solenoid as it should.
Is it right to have the intermittent 12v to the starter solenoid as the dizzy spins?
I should clarify that I have continuity on these circuits not 12v since the battery is not hooked up yet.
Old May 17, 2014 | 06:07 PM
Rimrock F1's Avatar
Rimrock F1
Your starter solenoid should have 4 terminals if it is a remote mount Ford starter solenoid. Battery + in, Battery+ out to starter when the solenoid is energized. S terminal or Battery positive in when the key is in the crank position and the I terminal or battery + out to the positive side of the coil in a negative ground system. The I terminal supplies 12v to the coil at cranking to aid in starting. Hope this helps some. I can't be sure from the description what terminals you are getting your readings on.
Old May 17, 2014 | 06:59 PM
71mach351's Avatar
71mach351
I'm get continuity from 12v battery '+ in' on starter solenoid to 's' terminal on solenoid when key switch is in crank position (just as it should). It also shows continuity when in the 'on' position only when points are made in distributor.
It looks as if there will be 8 pulses to the 's' terminal of the starter solenoid every time the rotor goes around?
Old May 18, 2014 | 08:46 AM
Rimrock F1's Avatar
Rimrock F1
If you are using a OHM meter to do this test and not a Volt meter this would be a normal reading.
Old May 18, 2014 | 09:54 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That doesn't sound right. Is your solenoid new? It sounds like maybe it is shorted internally.
Much as I hate to use this (because of the source) this is a diagram of the basic connections. There should be no power to the S terminal in the ON position. If there is continuity, there will be power. (You are using the S terminal on the ignition switch instead of a button, but same concept)
Old May 18, 2014 | 10:40 AM
71mach351's Avatar
71mach351
Yes, using an ohm meter. I hooked up the battery just to test if it would crank in the on position and it did not. Cranks only in the start position. I don't get it. But it works as it should.
Old May 18, 2014 | 11:06 AM
Rimrock F1's Avatar
Rimrock F1
Thanks for the diagram Ross, that should help. Using a OHM meter to test can cause some strange readings. One lead on the S terminal, and one on a battery positive source such a + side of coil or I terminal of key. Current flows through the winding's of the solenoid to ground, from ground through the closed points and then through the winding's of the ignition coil to the positive terminal. So you show continuity(be it at high Resistance) but the circuit is working correctly. This is especially prevalent when using a digital OHM meter.
Sounds like you are hooked up correctly. To further test you could disconnect the lead that goes to the starter then turn the key to the crank position. You should have 12V at the battery in terminal,S terminal, I terminal and the starter terminal. With the key in the on position you should only have 12V at the battery terminal and may have 6-8V at the I terminal that is coming from the positive side of the coil.
Old May 18, 2014 | 11:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Whew! That's a tortuous path! I can see where a continuity tester (buzz-box) would produce the situation.
Old May 18, 2014 | 11:57 AM
Rimrock F1's Avatar
Rimrock F1
I use an OHM meter that beeps when I have continuity. I often use it when I cannot see it and just listen for the beep. It messed with me many times when it found a path through a solenoid, gauge or bulb. I now use a power probe almost exclusively, has saved me many headaches. Still use the OHM meter for electronics and coils though.
Old May 18, 2014 | 02:42 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
This is a great thread, it shows the skill and knowledge of all involved. A well explained question, followed by answers that were to the point, precise, and helpful. I was not only educated by the process, but also very impressed. Well done guys!
pittdog1977
Jul 11, 2014 05:11 PM
floppywater
Jan 2, 2011 10:17 PM
78BigBlock09
Mar 30, 2010 02:48 PM
georgedavila
Electrical Systems/Wiring
Sep 2, 2003 09:20 PM
homer
Sep 20, 1999 11:36 PM
