frame coating.
Old Jul 27, 2012 | 03:56 PM
Jespo80f150's Avatar
Jespo80f150
frame coating.
hello all, ive seen so many people helping so much with others and its great to see. so i value peoples opinions here. and like the title says im getting ready to coat my frame. ive got a wire wheel im going to take all the surface rust off with. but im not sure what i should go with to coat the frame. i want something long lasting but fairly cheap in price. i was originally thinking to get a bucket of ryno lining or get some kind of sealer.
so my question is, in everyones experience/opinion. whats the best thing to have a long lasting thick coat for a decent price. thanks in advance for all the imput.
-Jerry
Old Jul 27, 2012 | 05:50 PM
CountryBumkin's Avatar
CountryBumkin
I don't know if this classifies as "cheap" but I like the POR-15 products. However it doesn't like a real smooth perfectly clean surface.
POR15, Inc. - Stop Rust Permanently - Repair Gas & Fuel Tanks
Old Jul 27, 2012 | 06:37 PM
Jespo80f150
thanks ill keep that in mind. im not going to strip the frame just get the loose surface rust off. anyone know how it works out just getting a bucket of tar? or i was thinking of getting cans of the rubberised coating they use for sealing boats.
Old Jul 27, 2012 | 06:52 PM
truckertrav's Avatar
truckertrav
You can get you some Rustoleum paint and do that.
It will help keep the rust from spreading.
After that drys well, you could brush or spray any coating(bedliner stuff or whatever) on and should work ok.
I used rustoleum under mine as I don't have any salt problems here.
I just cleaned it up a little with wire brush on grinder and sprayed it.
The half gallon or gallon cans are cheaper if you have a sprayer.
Good Luck and welcome to FTE. Trav.
Old Jul 27, 2012 | 07:33 PM
ctubutis's Avatar
ctubutis
Rustoleum is good stuff and is far cheaper.
I personally can't see spending a boatload of money on a ~30 yo truck to keep it from rusting... as if the truck is going to last another 30 years.
Zero Rust is nothing more than a Rustoleum-type paint
Old Jul 27, 2012 | 08:05 PM
GLR's Avatar
GLR
I know a guy here in NY That uses the Rustoleum Industrial paint on his trailers, with real good results.
Old Jul 27, 2012 | 08:06 PM
IntheTrees's Avatar
IntheTrees
I used Rustoleum semi-gloss black on my frame and engine bay. Very happy with the results and it was cheap to do. Where I live they have it in the extra tall cans for under $10.
Old Jul 28, 2012 | 06:36 AM
truckertrav
Also, True Value hardware stores have an oil based enamel called X-O Rust. It is about 30$ gal.
I used it on my 20ft utility trl and 18ft car hauler.
Works great!! Looks decent.
Works good on farm implements as well. Trav.
Old Jul 28, 2012 | 03:53 PM
Jespo80f150
ill look into that, i dont know if i have a true value around here but i can check home depot or ACE hardware. i want something thick so it wont chip away with rocks and what not. thanks again fellas.
55RoundTwo
16
Dec 17, 2017 10:21 AM
Can DO
Oct 28, 2008 05:40 AM
surfer55
Paint & Bodywork
Mar 13, 2007 03:02 PM
53C6_400ci
Feb 6, 2007 11:11 AM
Snowking
Jan 28, 2007 08:27 PM
