Frame prep?
Old Feb 4, 2007 | 11:18 AM
53C6_400ci's Avatar
53C6_400ci
Question Frame prep?
Hey everybody,
I'm looking for a consensus of opinion. Might be hard to come by, but what the heck! I'm wondering what the general consensus is regarding chemically treated frames vs. sand-blasting (for rust). My '53 frame is in pretty good shape, alot of surface rust, no cancer type stuff. I have wire-wheeled the big junk off, now I'm tossing up POR-15, Rust Bullet, or Rust encapsulator (Eastwood). Has anyone used either of these, and what did you think about it?
Thanks,
Glenn
'53 F100
'02 Focus
Old Feb 4, 2007 | 11:25 AM
Randy Jack's Avatar
Randy Jack
My choice would be to sand blast it, then powder coat it.
If that's too pricy, then sand blast and ZeroRust paint. I use ZR and like it a lot. Haven't used the others, but hear that POR15 is a pain to apply.
A chemical dip is problematic because the solution can get trapped and keeps eating away or comes out thru the paint later.
Old Feb 5, 2007 | 09:14 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Originally Posted by 53C6_400ci
Hey everybody,
Thanks,
Glenn
'53 F100
'02 Focus
I did much the same on my frame (wire wheel brushed) and then painted it with POR-15. Randy is correct in that it is a PITA to work with but if you use rubber gloves and don't get any on your skin you will be okay. Even though it is brushed on it dries like it was sprayed. I used it on my front and rear suspension, inside floor, and floor underneath also. I have not used ZR or Rust Bullet.
Old Feb 5, 2007 | 09:41 AM
Innovative Detailing's Avatar
Thumbs up Por15 experience.
Sounds like your frame was in about the same condition as mine, actually yours is a little more rusted from the looks of the photos, take a look at my photo gallery. My son and I used the Por15 system and its the "Bomb". It was very easy to use, flows very nice with a brush ( Definately use GLOVES ) or it will leave you with some serious new tattoo's that will take a while to come off. I dont plan on eating off the frame, and it is a daily driver so powdercoating was not my choice. But for the most part if you look at the frame, it looks remarkable the way the Por15 restored the metal.
Old Feb 5, 2007 | 10:03 AM
Brian_B's Avatar
Brian_B
I did not do it, nor do I know how it was cleaned........My frame was cleaned thouroughly (somehow-I think blasted) and they used Eastwood's rust encapsulator on it. So far there is no visible rust anywhere.
My only complaint is that they used the "RED" color on it. It will get top coated black some year. LOL
Old Feb 5, 2007 | 10:08 AM
ksmith203's Avatar
ksmith203
I have mine sandblasted and have found a place to powder coat frame for $150.00 so this is the way I'll be going from now on. More if you choose a special color, but if it what they are running that day it is just put in line and ran through.
Great find for Ohio truck builders..using the term very liberally!
Old Feb 5, 2007 | 10:14 AM
loholland's Avatar
loholland
There is more discussion concerning Por-15 down on the 47 and older forum if you want to skip down and check it out just for reference.
Old Feb 5, 2007 | 02:33 PM
GreatNorthWoods
This is what mine looks like after POR-15. I did the rear end and springs too.
Old Feb 5, 2007 | 04:17 PM
fking1's Avatar
fking1
Sand blast & powdercoat. Mine came out perfect.
Old Feb 5, 2007 | 11:52 PM
pcmenten's Avatar
pcmenten
A friend of mine got his old Harley frame powdercoated. Unfortunately, years of grease soaked into the metal and the powdercoating lifted off underneath where the engine is.
If you're planning on powdercoating, you'll have to degrease the frame before you media blast the frame. Even then, I'd check with the powdercoating people to see if they want to bake the frame to try to drive more grease out of the metal before they try to spray it. It's not the powdercoating that going to cost money/take time, it's the preparation before you powdercoat.
Old Feb 6, 2007 | 11:11 AM
50f1wrench's Avatar
50f1wrench
Thumbs up Frame Prep.
As for me I've used Rust Doctor on several projects. Works by chemical action to change Iron Oxide(rust) to Iron (something or other) that is like a coating that doesn't rust. Then just paint. It is very easy to use and can be brushed or sprayed. Easy clean-up too. It has a laytex base. Took about a gallon to do my frame. Just make sure you get good coverage in all nooks and crannies.and all surfaces. Try it you'll like it. Norm
DGMFORD
WTB - Parts & other
Nov 20, 2014 10:49 AM
HEAVY100
Oct 24, 2011 12:45 PM
53rat
18
Mar 11, 2009 11:41 PM
Fomoko1
46
Jul 2, 2007 11:42 PM
Stanstruck
Paint & Bodywork
Jun 28, 2004 03:48 PM
