He Also needs to Update STC Fitting at HPOP and Also Standpipes and Dummey Plugs at the Oil Rails under the valve covers
Get the Injector Oring from Aliant Power So he can change All Of them on each inject
The Ford OEM Oring Kit Shorts you 1 seal per Inject the One Seal in Questionhere is the Very TOP Oring that seals the HPO Rail To Inject
How hard is it to change that top injector O-ring if you happen to be in there?
Do you use a plastic hook to remove the old one or is that some other way?
Then I take it you dip the new one in oil and put it back in the injector?
Do I have this right?
Thanks
Sean
Thanks
Sean
Yes SIR ^^^ You Got It
A small Pick Set to Remove the Retainer At very Top once retainer out then Pull Oring Out
Iv never done it But the Only catch is The Retainer will Want to spin in its Bore Im shure its Doable
Just DONT Do it Around Open Valve cover incase the retainer Ring Goes Flying
Maybe pull the injector and do it in a box. You will have to
pull it to do the lower O-rings anyway. I guess you could
rig up a holder of some type and have some good light
when you do it so if and when one does fly it can be found.
Do you happen to have a photo of the O-ring installed?
Not Installed but just this Its the C-Clip you must pull to get the Black oring Below it in this Pic
Its the 2 Item FAR Right collum
If you go that far just as well do em ALL
The Fuel Rail Oring canWear and Leak Iv already been down that Road
When the fufel Rail orings leak same symtoms as BAD FICM with 1 exception Fuel in Oil and maybe Low Fuel Press I didnt have a Fuel Gauge so couldnt verify this
