WOW gots some code's
Old Jul 26, 2012 | 09:39 PM
quesey's Avatar
quesey
P0269 Cylinder 3 Contribution/Balance Fault
P0281 Cylinder 7 Contribution/Balance Fault ?
P0713 Transmission Fluid Temp. Sensor CKT High Input ?
P0470 Exhaust Back Pressure Sensor Circuit Malfunction.
don't know how inportant this one is my truck i have it deleated
P1280 ICP Circuit Out of Range Low.
has a new ipr but thinking it may have something stuck in it.i'm going to pull it and check
P0122 Accelerator Pedal Sensor Circuit Low Input.
had this one to but cant find it in the list p1748.
just bought this truck and am trying to figure it out.history on truck that i know.97 f250 4x4 auto 313000 miles probably not cared for buy the p/po.i got it from a guy who picked it from a kid that was driving the hell out of it from what he said.he installed a new glow plugs hpop ipr cps starter.has whitish blue smoke when started kinda clears up after it runs but if you can get it to rev it will smoke pretty good.thinking about injector orings and cleaning the ipr or replacing it.thanks john
Old Jul 26, 2012 | 09:44 PM
fordpride's Avatar
fordpride
I'd clear the codes and see which ones come back before I did anything
Old Jul 26, 2012 | 09:48 PM
quesey's Avatar
quesey
did clear them lol and started agian
Old Jul 26, 2012 | 09:50 PM
quesey's Avatar
quesey
well except for these
p1280
po122
po713
i think od light is flashing to
thanks john
Old Jul 27, 2012 | 03:25 PM
DarkStarMedia's Avatar
DarkStarMedia
Did you run a carfax/autocheck on it.... It could have a lot more than 300k miles... once the ODO hits 399,999 it rolls back to 300,000
Richard
Old Jul 27, 2012 | 04:19 PM
quesey's Avatar
quesey
No i did'nt.Not for what i gave for it.
Old Jul 27, 2012 | 04:22 PM
DarkStarMedia
ok... give... how much....
Richard
Old Jul 27, 2012 | 08:50 PM
quesey's Avatar
quesey
can't say for now.but way less than kbb.
anyway pulled the ipr and checked it everything looked ok and moved ok.guess i'll order orings for the injectors.being a 97 would it have ad's or ab's.know it don't matter for the oring's but i have 2 other sets of ab's laying around.
it's bud time
thanks john
Old Jul 27, 2012 | 08:59 PM
ReBilld's Avatar
ReBilld
It's not a bad looking truck.
Old Jul 27, 2012 | 09:05 PM
fordpride's Avatar
fordpride
If it's a Cali model it would have AB if not then it has AA
You can put the AB's in but you would need to have the PCM flashed for split shots
The AD didn't start till late 99
Old Jul 27, 2012 | 09:45 PM
quesey's Avatar
quesey
thanks
it's got 0 rust and front bumper an tailgate are the worst part of the body.
thought aa's an ab's were the same ? and ad's were the only differnce.
guess i'll pull a cover tomorrow
Old Jul 27, 2012 | 09:54 PM
fordpride's Avatar
fordpride
AA' and AO's are the same (single shots)
AB's and AD's are the same (split shots)
akmikek
20
Mar 30, 2016 10:45 AM
The Solar Guy
Mar 25, 2015 01:45 PM
a77bronc
Jan 6, 2010 10:04 PM
catman52987
Jun 25, 2009 05:40 PM
Copedawg
Aug 30, 2006 08:39 AM
