94 f150 E4OD shifting problem
Old Aug 7, 2012 | 06:34 PM
  #61
Truckin Bob's Avatar
Truckin Bob
Originally Posted by subford
Well I have never seen a PCM Computer for out era trucks that did not have the electrical capacitors in it.
The 1993 PCM Computer is a Push-Start Ignition system Computer and will not work right in a 1994 Truck that has a CCD Ignition System.
Hummmm........
I think you're on to something important here subford (Bill if I may).
In post # 14 you said "If it is not what I said above then you either have the wrong computer in the truck or a bad computer.
Very intuitive............good thinkin'.
My hat's off to you too.
Bob
Old Aug 13, 2012 | 01:27 PM
  #62
tupperpup's Avatar
tupperpup
Mine is also a 1994 F150 automatic with transmission issues. If I start out in 2nd gear up to around 40-45 the transmission tends to shift okay. If I start out in "D", it tends to shift anywhere it wants, searching for gears. Sometimes it wants to shift down or up within a range of a couple miles per hour. I'm hoping all it is, is a change of transmission fluid,,, but from all you pro's out there, looking for any other ideas. Besides this transmission "problem" the truck runs great. Appreciate your guys thoughts.
Mason94f150
Jun 21, 2014 03:10 PM
CCope94
Jul 31, 2012 06:44 AM
CCope94
Jul 26, 2012 08:54 AM
tjsadler
Aug 27, 2002 03:17 AM
