How to replace the intake gasket?
Old Aug 14, 2012 | 02:07 PM
Buzz44's Avatar
Buzz44
Originally Posted by tbm3fan
If he is lucky he might see some of the new Fel-Pro intake gaskets. I noticed that the end strips now have a peel off adhesive already on one side. Peel the paper, press onto the intake, wait a little and then install intake. The strips get a pretty good grip and do not slip.
Now why didnt I think of that ?????????
Old Aug 14, 2012 | 11:00 PM
tbm3fan's Avatar
tbm3fan
Nobody thinks of the obvious. How long have they made those gaskets, with those ends and the fact that this adhesive ability has been available for 20-30 years. So even Fel-Pro didn't see it.
Old Aug 21, 2012 | 06:45 AM
willowbilly3's Avatar
willowbilly3
If everything is clean you really don't need any kind of goop on the gasket areas. I like to use spray High-tack on the heads just to hold the gaskets in place, especially if you use rtv on the ends because now you don't have the end gaskets to hold them up. If you do use the rtv on the ends, let it set overnight before you start the engine or you run the risk that crankcase pressure/vacuum will blow/suck the rtv out of the gap.
BigMikeUGA
Oct 14, 2016 10:22 AM
1968FordF100
May 29, 2012 12:04 AM
TexasTornado66
Jul 1, 2010 10:58 AM
sammycooks
Feb 22, 2010 02:38 PM
Unimog005
13
Sep 9, 2006 08:29 AM
