Starting Issues
Old Jul 26, 2012 | 03:58 PM
george horner's Avatar
george horner
Starting Issues
I'm having starting issues with my 7.3, I wait for the light to go out
to start it. When I try to start it up, it acts like the batteries are bad.
I just replaced them and the have good voltage. But if I start it without
waiting for the light to go out, then it will start up fine.
Old Jul 26, 2012 | 07:46 PM
fuzzy1626's Avatar
fuzzy1626
Check your batt. cables. All the connections have to be clean and tight. If the cable insulation looks burnt next to the connectors, you probably have corosion in the cable under the insulation. Does the starter spin faster before the light goes out than it does after it goes out?
Old Jul 27, 2012 | 11:00 AM
george horner
Starting Issue
Yes it will turn over faster and start up, if I do not wait.
Old Jul 27, 2012 | 11:46 AM
farmert's Avatar
farmert
What size are your batteries? These trucks call for at least 825 cold cranking amps, if I remember right. If your batteries are to small you could get this problem.
jprankin
22
Nov 18, 2014 06:53 AM
1brenth
Mar 17, 2014 03:46 AM
jc2
Nov 12, 2007 06:29 AM
lexasgs400
Sep 10, 2007 11:39 AM
Rich in CO
Oct 23, 2005 10:02 PM
