Sponsored by: Real Truck
plug change on 08 v10
Old Jul 28, 2012 | 08:39 PM
Gage2502's Avatar
Gage2502
Ya there is another video saying to remove the plugs while the engine is hot and use an impact.
Also I was reading that the only one piece plugs are brisk and champion plugs?
So no Motorcraft plugs in 3Vs?
Another thing I read was about using Marvel Mystery Oil in the gas tank to help loosen the carbon?
~Gage~
Old Jul 29, 2012 | 07:21 AM
redbull660's Avatar
redbull660
I've also been thinking about doing a plug change on my 08 v10. It has 59000 miles on it and runs like its new but I thought it wouldnt hurt to change them. This way I would know it had the newer one piece plugs in it.
Old Jul 29, 2012 | 12:57 PM
dkf's Avatar
dkf
~Gage~
Yeah the Motorcraft and Autolites are still the two piece design. I have not seen any different. Brisk and Champion both offer one piece designs. I like the Champions J wire design also.(less shrouding of the spark kernal and easier to gap)
Yeah I say that video by srmastertech I believe. Aluminum softens, gets even more "sticky" and is easier to gall the hotter it gets. The heads are a high silicon aluminum casting so it is not as bad but you still risk galling and damage. His reasoning for doing it hot is is probably that the head recess is expanded some. The possible thousanths of an inch or two of expansion is not worth the chance of galling and/or damage IMO. The impact gives it a few smacks to knock it loose however you have no feel and can do damage before you know it. The first video you posted has a much better procedure IMO. He may be a master tech and not have had any problems but they are not his vehicles. He probably never does a change on them again since the customer probably traded the vehicle off for someone else to deal with. Not knocking him I'm just skeptical of his method over the long haul.
The Marvels Mystery oil cleans out carbon and lubricates the top end. Just double check that it is O2 and catalyst safe. (I'm almost sure it is) Follow the directions on the bottle. I have used MMO in every tank in my 74' for years already to help lubricate the upper cylinder areas and as a fuel stabilizer.
zman300
Jul 26, 2009 01:29 PM
mxracer49
2004 - 2008 F150
39
Mar 29, 2009 10:21 AM
fdnylax
Modular V10 (6.8l)
23
Jan 19, 2009 02:57 PM
Scott Y
Modular V10 (6.8l)
Aug 16, 2008 12:05 PM
kelro
Modular V10 (6.8l)
Jul 29, 2005 06:32 AM
