Modular V10 (6.8l)
Plug Change time?
Old Aug 14, 2008 | 03:21 AM
Scott Y's Avatar
Scott Y
Plug Change time?
I bought an 05 V10 earlier this year with only 8,000 miles on it. It was only used to haul a truck camper and the owner got rid of it due to gas prices.
Anyway, it now has just 9,000 miles on it. But since it is 3 years old should I worry about the plugs?
Runs just like brand new, so no problems at all. Just curious if time makes as much as difference as milliage with plugs?
Thanks
Scott
Old Aug 14, 2008 | 07:21 AM
dkf's Avatar
dkf
Might be a good idea to pull each plug, put a dab of anti-seize on each and reinstall them. Those plugs have a tendency to seize fast at the long grounding collar. I don't see a reason to replace plugs with only 9k miles on them. Make shure you torque them to factory specs.
Old Aug 14, 2008 | 12:43 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
After 3 (or 4 depending on when it was made) years, I'd definitely make sure they come out.
BE CAREFUL.
There's a TSB for doing the plugs in the 3-valve, here's the TSB for the 5.4L:
06-15-2***SPARK PLUG REMOVAL INSTRUCTIONS - 5.4 3V
I seriously doubt you have to be as careful as they say in the TSB, but it can't really hurt.
Old Aug 15, 2008 | 11:03 PM
someday's Avatar
someday
so this applies to v10s as well...are new plugs better since it only applies to 2005s
Old Aug 16, 2008 | 10:17 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
At 9K I wouldn't even worry about plugs, I think more damage is caused to motors with aluminum heads because the plugs are removed and played with to much. I never changed the plugs in my 2000 V10 work truck after 100K without any problems, I changed the plugs in my 2000 V10 play truck at 65K and it was a waste of time and money because the looked great but I had new ones so I put them in. I'm a firm believer in IF IT ISN'T BROKE DON'T FIX IT. If you get 100K on the truck then worry about plugs.
Denny
Old Aug 16, 2008 | 10:35 AM
dkf's Avatar
dkf
2005-2008 6.8l 3Vs, 2004-2008 5.4l 3vs as well as the 4.6l 3Vs use the same plug design. Ford redesigned the plugs again in late 08' production to a new plug to elimate the problems with the previous plugs. All 4.6l, 5.4l and 6.8l 2V engines use completely different plugs than the 3Vs.
Old Aug 16, 2008 | 12:05 PM
krewat's Avatar
krewat
And if I had left the plugs in my 2-valve V10 alone for that long, I would have had at least one pop out by now from corrosion.
Not to argue with you, but it's important to do something about the plugs when it's been a few years, no matter what mileage.
I still think it's a good plan to do the plugs on the OP's motor NOW instead of later, especially if he intends on keeping the truck for a long time.
gr8scott72
May 27, 2009 02:51 PM
boogs
Apr 22, 2004 06:55 AM
Scott'00Rngr
3.0L V6
Sep 30, 2003 02:24 AM
scottlane
Jul 6, 2003 08:28 AM
