84 window wipers
Old Jul 26, 2012 | 01:35 PM
crazyfordguy's Avatar
crazyfordguy
84 window wipers
help!! i have an 84 f250 with intermittent window wipers and i cant get any power coming into the switch. Any advice would be greatly appreciated
Old Jul 26, 2012 | 02:51 PM
86fordtruck's Avatar
86fordtruck
Welcome crazyfordguy! Lots of good folks here who know more than I do about these problems, but maybe I can hit some really simple things. Let's face it, even a stopped close is right, twice a day. First and most simple, have you checked the fuses? Also, have you tried running a jumper from the battery to the positive in on the motor, with the negative in grounded to confirm that the motor works? Two easy things to check that will help narrow down where to search for answers.
Good luck.
Old Jul 26, 2012 | 03:23 PM
crazyfordguy
ya. i ran a jumper and the motor works fine. i couldnt find a fuse however it turns out that the switch has a built in cicut breaker. i ran all the tests and its fine. i think my hot wire is shot but i dont know witch one it is. i know the wire comes from the key but i cant trace it. the truck is an XLT with a rotary switch so i dont know if that would make a difference
Old Jul 26, 2012 | 03:45 PM
dustybumpers's Avatar
dustybumpers
There is a wire that comes off the back of the switch that needs to be grounded, It won't work unless this wire is hooked up
Old Jul 26, 2012 | 04:26 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The wiper switch gets it's power from the ignition switch.
Black/Light Green Hash wire.
The ignition switch has to be in run, or accessory to test the wire for 12v power.
Old Jul 26, 2012 | 04:31 PM
dustybumpers
The intermittent wipers have a ground wire on the side of the switch, that is NOT in the harness
Old Jul 26, 2012 | 04:51 PM
81-F-150-Explorer
Correct, but it's not needed to test the power wire.
Using a test light, he can test the Black/Light Green stripe power wire, with the intermittant wiper switch disconnected from the main harness.
He needs to test this in the run or the accessory position.
If no power on this wire, he needs to trace it back to the ignition switch and do a continuity check between both ends of the wire.
If there is power, then it's the switch, govenor, or a problem forward from the switch, and various wiring, including the ground wire you speak of.
Old Jul 26, 2012 | 05:20 PM
crazyfordguy
i found the black/ green wire,but no juice. it comes from the steering column? cause i dont have a black/green hash wire going up the column
Old Jul 26, 2012 | 05:23 PM
crazyfordguy
the only wires i have on the column that are hot are light blue, yellow, and white with pink
Old Jul 26, 2012 | 05:25 PM
crazyfordguy
any of you guys have a diesel cause the wiring might be different to accomodate the glow plugs
Old Jul 26, 2012 | 09:02 PM
ctubutis's Avatar
ctubutis
See if this helps you:
https://www.ford-trucks.com/forums/1...l#post11039831
Old Jul 27, 2012 | 11:43 AM
crazyfordguy
the farthest back that i can trace that black/green wire is where it enters the wiring harness by the switch. i cant seem to find it anywhere after that.
Old Jul 27, 2012 | 01:10 PM
ctubutis's Avatar
ctubutis
Did you look at the wiring diagrams in the thread I posted above?
Old Jul 27, 2012 | 01:11 PM
81-F-150-Explorer
The ignition switch is located at the bottom of the steering column behind the dash. It's bolted to the top of it.
The wires doesn't actually enter or go up the column. The Ignition Lock has a metal actuating rod that goes down the length of the column that connects the two components.
It's not easy to reach without dropping the column off it's dash support.
That thread that CTUBUTIS is pointing you to has some great information in it.
Old Jul 27, 2012 | 04:35 PM
crazyfordguy
thanks man. wow i feel like a complete idiot. i couldnt find the wire for like a week. now that i found it they should be running by today
turbo740922
1997 - 2003 F150
Aug 10, 2011 02:28 PM
slowjet
Apr 26, 2010 12:12 PM
loquito
1978 - 1996 Big Bronco
15
Mar 1, 2004 08:53 AM
vettepin
Aerostar
Sep 4, 2003 07:11 PM
pa_brian
Electrical Systems/Wiring
Aug 25, 2002 06:28 PM
