Drivers window wont go down. No sound nothing. Motor works when hot wired. Window will roll up with switch. Signal from switch (one touch and regular down) goes through the door into the cab and makes it to the GEM. No wire breaks. Motor is good, switch is good. Relay is good. I cant figure this one out.
Other than putting my own relays in the door, what are my options here?
Fixed it. No one touch down feature but I got it to roll down. All I did wa run a wire from the down pole on the switch directly to the hot-down wire in the motor. I cut the wire on the motor so it wouldn't go back into the cab and cuase it to short (as its ground when no power is sent to it). It works just like it should now.
