6.0 Turbo - Flutter
Old Jul 26, 2012 | 08:54 AM
Scoutmaster's Avatar
Scoutmaster
6.0 Turbo - Flutter
2006 6.0 Diesel F350 43K miles - Just reconditioned turbo ... not too bad .. some rust and coking .. installed Banks dual exhaust and Banks air cleaner ... Took it out for a test drive ... blew off turbo exit intercooler hose ... cleaned and re installed. 2nd test drive lag in spool up good boost after spool ... multiple flutters on release of pedal. DID NOT change the VGT actuator or the MAF or the EBP ... any suggestions on the flutter ... it was never there before the cleaning .... cleaned because of over/under boost codes. Do I need a new EGR valve?
Old Jul 26, 2012 | 12:43 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jul 26, 2012 | 07:29 PM
BLADE35's Avatar
BLADE35
need to check MAP & EBP & Baro at KOEO
get a scangaugeII
Welcome to FTE
Old Jul 26, 2012 | 07:57 PM
69cj's Avatar
69cj
Haven't heard too many good reviews on a/m air cleaners. Staying stock is the majority op.
Old Jul 26, 2012 | 08:03 PM
BLADE35's Avatar
BLADE35
missed this in first post
How much Antiseize did you smear on the unisone ring???
Old Jul 27, 2012 | 12:57 PM
Scoutmaster
Very light film on the Ring and on the surface in the Turbo where the vanes rest ... took it out for a test drive last night on the highway great acceleration ... not much flutter .. still can make it happen if I try ... will the Scangauge II help diagnose the sensor issues if any?
Old Jul 27, 2012 | 01:13 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I think that FLUTTER is actually a "turbo fart". This is very common with the 6.0 as it doesn't have a waste gate so on a quick release of the go pedal, exhaust gas will attempt to flow back up thru the turbo resulting in a cough/flutter/fart noise. This will happen more if the engine isn't fully warmed up.
Old Jul 27, 2012 | 06:22 PM
cheezit's Avatar
cheezit
banks air cleaner is gonna make it worse too. the oem dampens the sound a bunch.
Old Jul 27, 2012 | 06:42 PM
BLADE35's Avatar
BLADE35
Interesting never thought of that a Muffler too
The OEM filters are the best so if you still have it might be worth throwing it back on the OEM Air filter that is
Old Oct 16, 2012 | 03:35 PM
fletchstang's Avatar
fletchstang
Clean the actuator:
unplug the wire
take out the 8mm bolt holding on the clamp/actuator
twist/turn/pull on the actuator....
carefully take it out straight....its about 3 inches long
inspect the o rings
use carb cleaner to clean it....spray it everwhere, inside and out.
push in the end with your finger/thumb.....spray inside again....everywhere.
It's worth a try.
1 hr total (a newbie, checking other things as well) & a 5 dollar can of carb cleaner.
mark_5102
Jun 9, 2019 09:36 PM
jokerj280
Dec 25, 2016 07:59 PM
Wyatte
Sep 26, 2016 08:23 PM
markle
Sep 13, 2012 09:04 AM
BobDG
Feb 8, 2008 04:39 PM
