Sponsored by: Real Truck
v10 redlines at where?
Old Jul 25, 2012 | 07:45 PM
christopherdrop's Avatar
christopherdrop
Out of curiousity (and perhaps bravado), I took my '99 F250 SD CC with lovely rusted utility bed out for a full blast, pedal to the metal test.
This POS has been bogging on small hills, threw a CEL (that's now dark) and almost left me stranded in the middle of BFE. So today, I tried to see if it would bog again and I floored it. I mean FLOORED it to 6K 90mph+.
Does this thing redline? No redline on the tach...
FWIW, it didn't bog at all. Just got up on it!
Old Jul 25, 2012 | 09:43 PM
Boss08v10's Avatar
Boss08v10
when the pcm or computer tells it it is at redline, you can not over rev this way. Flooring the pedal, the truck will not let you go past the redline. If the truck is a manual I think it is possible to over rev on a down shift but that is about the only to do so.
Old Jul 25, 2012 | 09:47 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I think he means when does the PCM tell it to stop reving.
Old Jul 26, 2012 | 01:31 AM
Fordfanatic4life's Avatar
Fordfanatic4life
if memory serves me right i think the PCM fuel cutoff is 6500RPM but im not sure..
Old Jul 26, 2012 | 02:03 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
yeah i upped my shifts to 5,100 for a few years with no issues. i floor it very often! lol i would not worry unless it starts making odd noises.
Old Jul 26, 2012 | 07:55 AM
dkf's Avatar
dkf
Since your 99' has an NPI 2V it may be lower but the 03' and 04' V10 with the 2V PI I've tuned had the rpm limit in drive and in neutral set at 5300rpm. If your engine actually spun to 6,000rpm there probably would have been pieces from a rod saying uncle.
Old Jul 26, 2012 | 08:09 AM
BVR PLZR's Avatar
BVR PLZR
A V10 is a high revving engine///that's the advantage of having more but smaller pistons than a V8. You don't even get the full rated horsepower until 4750 rpms (that's for the 362 hp, 3 valve version, iv cringed pulling my 5er up hills hit 5k a couple times but im assured by my garage just drive it however i typically try to keep under 4k
Old Jul 26, 2012 | 09:18 AM
GVS's Avatar
GVS
When it starts makeing odd noises it's probably too late!
chrisal1234
Engine Swaps
Sep 17, 2013 06:18 AM
bgblk71merc
Modular V10 (6.8l)
Apr 20, 2010 07:54 AM
biz4two
Modular V10 (6.8l)
Nov 19, 2005 10:31 AM
swanee
Modular V10 (6.8l)
Jun 14, 2004 09:09 PM
jmart233
Apr 16, 2003 09:30 PM
