Sponsored by: Real Truck
Head Studs
Old Jul 25, 2012 | 04:12 PM
catherf-350's Avatar
catherf-350
Head Studs
At what point of using a performance chip do i need to think about getting aftermarket head studs is adding a extra 100 hp and 200lbs of torque to much for the factory head studs
Old Jul 25, 2012 | 04:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
On what engine?
Assuming you mean a 6.0L Power Stroke, head studs would be my first mod, along with cat and EGR delete.
Old Jul 25, 2012 | 04:50 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
If you have a 6.0L:
PHP has done some cylinder pressure testing, and Bill claims that his Econ and 40HP FICM tunes, and PCM tuning under 40HP are safe for non-studded trucks. Matt at Gearheads writes an SRL tune specifically for non-studded trucks. It's still a crap shoot, there are so many variables in how the heads are put on that any given truck could have issues, even with stock tuning. If you're running any type of pre-loaded tunes, or any kind of shift-on-the-fly tuning, you need to reconsider and switch over to custom tuning. Running canned tunes is asking for trouble.
Any canned tune claiming 100HP will almost certainly blow your heads, they usually screw with the start of injection table and make it really aggressive to get that extra power, and that jacks up cylinder pressures to the point where there's no way to keep the stock bolts from stretching.
This is specifically for the 7.3Ls, but it's still a good writeup from Bill about tuning HEUI diesels:
http://www.powerstroke.org/forum/99-...general-2.html
If you have a 7.3L:
Buy an FU chip or a Gryphon and tune away. The stock injectors probably can't move enough fuel soon enough to get the cylinder pressure to the point where you lose the heads.
http://www.gopowerhungry.com/_fu2_chip.shtml
http://www.gopowerhungry.com/_gryphon_cts_diesel.shtml
Old Jul 25, 2012 | 04:54 PM
AGE mechanic's Avatar
AGE mechanic
I would recommend any increase over stock. If you want to play at all do the ARP studs.
catherf-350
Jul 24, 2012 03:46 PM
David85
Nov 24, 2007 10:16 AM
sturoe
Sep 25, 2007 07:18 PM
66ford400
Jul 6, 2006 09:25 PM
