2001 7.3L Overheating underload
Old Aug 7, 2012 | 05:09 PM
4EXTRDR's Avatar
4EXTRDR
Why are you revving 3000 rpm's? Are you running with OD off and trying to fly up the hill? if i am reading your post correctly, i would say it's the driver causing the overheat....3000 RPM's would probably cause it to run hot even without a heavy load. Our engines are good but any diesel would run hot up hills, in the heat & pulling heavy.
Old Aug 9, 2012 | 10:40 PM
DKelleyTX's Avatar
DKelleyTX
The replies above regarding the fan clutch problem was right on. The fan clutch wasn't working properly and caused my radiator to finally go. Luckily the load was delivered and new radiator and fan clutch being repaired. Only reason the rpm's were up was to test the fan. Was doing 55mph and on flat terrain, it got me to my destination.
Gunnerboy
Jul 28, 2017 07:12 AM
mprice
1978 - 1996 Big Bronco
Jan 18, 2010 10:21 PM
-jeremy
Jul 21, 2005 01:42 PM
broncoray
Bronco II
Dec 11, 2003 03:19 PM
payed4
Jul 24, 2003 01:59 AM
