1950 F2
Old Jul 23, 2012 | 11:37 PM
Fifty Ftwo's Avatar
Fifty Ftwo
4wd Low
1950 F2
I'm new. I have a 50 F2 which is maroon in color. I believe that it is the original color but I haven't seen that maroon is a standard color. Can someone tell me how I might confirm the original color?
Thx!
Old Jul 24, 2012 | 12:04 AM
52 Merc's Avatar
52 Merc
I don't recall a maroon color being on the standard color list, but anything is possible with special orders. Most people don't go through the trouble of repainting every square inch of these trucks when doing a color change unless they're doing a complete and total restoration. Unless that has been done on your truck, there's very likely some hidden areas somewhere that would still have the original color; under the seat, behind the gas tank or interior trim panels, behind the firewall insulator under the dash, maybe even behind the access plates on the insides of the doors. Sometimes research on old trucks is a little like an archaeological dig. And that's part of the fun. Welcome to the forum!
Old Jul 24, 2012 | 12:10 AM
harleymsn's Avatar
harleymsn
Check the build code stamped on the firewall. The original color code should be there.
Old Jul 24, 2012 | 12:42 AM
old_dan's Avatar
old_dan
Here's a VIN decoder that should work for your F2. Look for the digits that indicate the color code:
Old Jul 24, 2012 | 01:41 AM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Well, I suppose that the 1949 year VIN was a different animal, as it looks nothing like the 51-52 series you show in the chart. The VIN for Gertie goes 98RDXXXXXX. The six trailing X's are all numerals. Is there a way to decode these numbers?
Sorry if I hijacked, but I figured the question was germane since the O.P. has a 1950, and I would assume the VIN scheme was the same as in 1949.
Dave
Old Jul 24, 2012 | 08:08 AM
old_dan's Avatar
old_dan
Oops... That decoder is for 51-53 VINs. Maybe someone else with earlier information can weigh in.
Old Jul 24, 2012 | 08:11 AM
old_dan's Avatar
old_dan
Typing on a cell phone is tough.... Thats a 51-52 chart
Old Jul 24, 2012 | 08:47 AM
51PanelMan's Avatar
51PanelMan
The only way to tell anything additional on 48-50 trucks, like the production date, plant and color, is by finding the stampings on the cowl. It's usually stamped in the center of the cowl by the top.
Old Jul 24, 2012 | 12:22 PM
Gertie-The '49 F2
Ilya, I assume the stamping is into the sheet metal of the cowl itself, and not on a plate of some sort. I say this because my '49 has been in the family since around '69 or so, was a very low mileage vehicle at the time, thus VERY original, and the only plates are on the firewall and glovebox door.
I'll have to take a close look this weekend when I am out putting in brake lines, master and wheel cylinders, thermostats, vacuum hose, wheel seals, etc., etc.
Dave
Old Jul 24, 2012 | 12:27 PM
arctic y block's Avatar
arctic y block
Let's see some pic's?
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Jul 24, 2012 | 02:46 PM
aussiecowboy's Avatar
aussiecowboy
Here is a link to 1950 Ford colour chips
???txt.title???
Old Jul 25, 2012 | 01:03 AM
51PanelMan's Avatar
51PanelMan
Yes, the stamping is in the sheet metal of the cowl and not a separate plate. Look for the sanded portion of the cowl in the upper area directly below the seam.
Here it is up close.
PNYGTA
16
Jun 6, 2014 09:13 PM
shareec70
Jan 1, 2013 01:43 AM
alvald83
Jun 28, 2010 11:04 AM
ms_michelle
16
May 1, 2010 04:26 PM
wizzard351
Dec 28, 2007 08:13 PM
