Cooling Fan
Old Jul 23, 2012 | 10:54 PM
1972RedNeck's Avatar
1972RedNeck
Cooling Fan
Yesterday I was looking at the motor in my '66 when I noticed one of the rivets had fallen out of the flex fan (we all know what flex fans can do). Needless to say my truck does not have a fan any more. With the flex fan the truck could get a little hot putting around. I what to upgrade to a fan that pulls A LOT of air (why not?) What would you all recommend? Clutch fan?
Old Jul 24, 2012 | 01:39 AM
63' f100's Avatar
63' f100
I think an electric fan is the way to go. It uses none of the engine's power and it is put as close to the radiator as you can put a fan.
Old Jul 24, 2012 | 05:52 AM
jowilker's Avatar
jowilker
Redneck, These trucks have a huge frontal opening, keep it moving 20 mph and you don 't need a fan at all. The truck will not sit still idling very long without the temp gauge moving up. Keeping a good 50/50 mix is important too. Just replace the fan, enjoy the heat.
If ya gotta go letric, have at it.
John
Old Jul 24, 2012 | 09:23 AM
66f-100's Avatar
66f-100
If you don't have a shroud on it, I would consider putting one on. It will run cooler and it will be a little safer. I put one on mine and it runs plenty cool even in 100 degree weather.
Old Jul 24, 2012 | 10:22 AM
37 Ford guy's Avatar
37 Ford guy
If you're going electric, I've read the Mark VIII and Tbird fans are really powerful and cheap at the salvage yard. You'll probably have to upgrade your alternator if you go that route...I'm sure if you do a search you'll pull up quite a bit of info....
Old Jul 24, 2012 | 08:43 PM
1972RedNeck
Electric doesn't take any of the engines power? It doesn't make the alternator work harder which makes it harder to turn? I don't want to run electric anyway. I keep a 50/50 mix in all my vehicles. If I keep the truck above 15 mph it stays cool. This is my ranch truck and at times, I am running 5 - 10 MPH for over 1/2 hour. I also tow up to 20,000 lbs. at times. I will be getting a shroud too.
Is a clutch fan a good choice?
Old Jul 25, 2012 | 07:39 PM
1972RedNeck
Summit racing offers heavy duty and severe duty clutches. What's the difference?
Old Jul 25, 2012 | 07:58 PM
chris66's Avatar
chris66
i am running a clutch fan with a six or seven blade fan and no shroud its been very hot down here and mine has never overheated
factory594x4
Mar 11, 2007 12:15 PM
dono
1983 - 2012 Ranger & B-Series
Apr 3, 2002 11:01 PM
