why 4wd not working
Old Jul 30, 2012 | 09:04 AM
srqdiesel chef's Avatar
srqdiesel chef
more details; when I spun the driveshaft in 2wd it spun freely and the axles spun too. as soon as I shifted into 4wd, I could not move it at all, not even 1 revolution. so I left it in 4x and jacked up the front end and I could spin a tire freely, axles did not move at all. I have the TTB front end, does that make any difference?
Old Jul 30, 2012 | 10:56 AM
farmert's Avatar
farmert
I'm not familular with auto locking hubs of this generation, but can you lock them manually? Not being able to turn the driveshaft when the transfer case is in 4wd tells me the transfer case is doing its job, and the axles turning when the drive shaft is rotated when the transfer case is in 2wd says the diff is working, so this points to the hubs. If funds are available, get the manual Warn priemum hubs and be done with the auto lockers. The only difference the TTB would make is if you had a D44 or D50, and that would only be in which hubs you need. The D 50 and the solid axle D60 take the same locking hub.
Old Jul 31, 2012 | 08:03 AM
srqdiesel chef
will these work and is price ok?
WARN 9790 4WD Locking Hubs Set Dana GM Ford 44 Spicer 1/2 3/4 Ton 19 Spline Axle 00 12748 09790 7 | eBay
Old Jul 31, 2012 | 08:41 AM
farmert's Avatar
farmert
Those hubs are for a D44, and I think you need hubs for a D50/D60. Measure acoss the hub, a D 44 will be approx.3 1/4 inches across, while a D50/D60 will be approx. 4 in. The premium hubs are usually in the$210-$250 range. I have never converted from auto lockers to manual, but from what I've read you will need to change the spindle nuts To the manual type also. These are the nuts WARN 32721 SPINDLE NUT KIT DANA 60 50 HUB AXLE WHEEL BEARING SET PARTS 012748327219 | eBay These are the premium hubs WARN 38826 4WD Premium Manual Locking Hubs 1 Ton Dana Spicer 60 50 GM Ford Dodge 00 12748 38826 5 | eBay These are the standard duty WARN 11690 4WD Manual Locking Hubs 1 Ton Dana 60 50 Ford Chevy Dodge Front Axle 00 12748 11690 5 | eBay If you want to take a chance on used, these will work Warn 4WD Manual Locking Hubs 30 Spline Dana 60 and 50 4x4 | eBay
Old Aug 1, 2012 | 05:27 AM
srqdiesel chef
found a pair in salvage yard for $40, 1st one came off in about 20 minutes, 2nd one not so much. What is the easiest way to get that &%&^ retaining ring out of it's little groove? I popped the tip off of 2 of my little screwdrivers trying to get it out of the groove and bout passed out from heat stroke and ended up telling dude I would be back today to get the other half. checked temp with the thermocouple on my meter and the concrete I was sitting on registered 127º!
Old Aug 1, 2012 | 09:08 AM
farmert's Avatar
farmert
Ya, that ring can be fun to remove. I've seen 2 different ones, a single wire type and the other is a spirial flat one. On both you need to get the end started out of the groove. The wire type,one screw driver to pop the end from the groove, and another to pry it out. The spirial one, start like the wire one,but this one makes 2 laps around the inside of the hub so you just need a little more time. You will get it, today it will probably about jump out, ha!
Old Aug 1, 2012 | 03:18 PM
srqdiesel chef
5 frikkin minutes to get the ring out this morning!!! so I wandered around and found a hood release cable I needed and that took longer to get off. Tomorrow I'll start the switch, hope they are the right ones, if they're not, I figure I paid for a lesson in how-to.
Old Aug 1, 2012 | 10:06 PM
84-6.9L's Avatar
84-6.9L
Worst case all you would need is the conversion kit. I did this swap on a 90' half ton and the only thing I had to change was to leave out a splined spacer that went behind the auto hub. However the hub design my have changed.
mesnipe
Jan 10, 2015 11:40 AM
drburnerllc
Sep 10, 2012 03:31 AM
HKusp
17
Jun 3, 2010 07:56 PM
02GrayPowerStroke
Jan 14, 2009 10:28 PM
Lashlaroo
1978 - 1996 Big Bronco
Sep 11, 2001 08:19 PM
