1978 - 1996 Big Bronco
B/W Transfer just stoped working
Old Sep 8, 2001 | 11:41 PM
Lashlaroo's Avatar
Lashlaroo
Wow! when it rains, I get soaked
89 I/6 with the Borg Warner transfer case. Got stuck today :-) in a small mud puddle (dang georgia clay) shifted into 4wd and nothing? all the lights worked. Hubs locked fine? the normal click when turned to lock. 4wd low range worked (back end only)No odd sounds, other than the snikkering from the right seat.
I hope this problem rings a bell with some of you.
Are these cheep/easy to fix (hehe) or should I just let 300,000+ miles be good enuf.?
Old Sep 9, 2001 | 03:38 PM
DantheMan's Avatar
DantheMan
Maybe a u-joint? I'm sure a transfer case just don't quit at the drop of a hat. My 90 bronc had a problen similer, but that was pushbutton 4x4, bad shift motor. Maybe take a look at the linkage and make sure no pin or something fell off. It's probably some minor glich. I think you would hear SOMEthing if the t-case went out.
Old Sep 9, 2001 | 04:15 PM
Lashlaroo's Avatar
Lashlaroo
Thanks for the reply. The drive shaft is still attached. It looks like the switch for the 4x4 and low range lights are inside the transfer housing. ??
And to add some salt to an open sore. The A/C compressor went south today.
I think this old horse is about to be put to pasture.
The dealer in town has a 00 F-250 SD Diesel 4x4 that's calling my name.
Old Sep 10, 2001 | 09:15 AM
beratte's Avatar
beratte
I'd do 2 simple tests. First lock the hubs (I assume you have manual hubs). Mark the drive shaft and then drive a foot or two and see if the drive shaft has moved. If it does then your hubs are good. Now unlock the hubs and shift into 4WD. Again mark and check your drive shaft. If the shaft moves then your transfer case is good. I would bet your problem is in the hubs. If you have manuals you probably just need to remove them and clean them. If they get too much grease in them (slung out from the wheel bearings over time) they won't work. If you have automatic hubs then you can try cleaning them but you will probably need to get a hub service kit from Ford or replace them with new manuals. Good luck, Ben
Old Sep 10, 2001 | 03:43 PM
JBronco's Avatar
JBronco
Sounds like hubs to me? Yours (and a/c compressor too) made it to 300 K? pretty cool!
Old Sep 10, 2001 | 03:44 PM
JBronco's Avatar
JBronco
PS - Broncos are cool, but did you ever have something last longer than you wanted it to? Like that roll of masking tape in your toolbox?
Old Sep 10, 2001 | 11:21 PM
Lashlaroo's Avatar
Lashlaroo
Had a woman that lasted longer than I wanted. does that count?
I will try cleaning the hubs
Thanks
Old Sep 11, 2001 | 08:19 PM
billyb's Avatar
billyb
