why 4wd not working
Old Jul 23, 2012 | 08:36 AM
srqdiesel chef's Avatar
srqdiesel chef
why 4wd not working
when I shift into 4x4 the dash light comes on but the front axle does not. where should I start looking. I've never worried about this b4, but I got drawn for a hunt down in Big cypress and it is some kinda serious muddy down there!
Old Jul 23, 2012 | 09:00 AM
Forddiesel17's Avatar
Forddiesel17
Are your front hubs locked in? Check the linkage at the transfer case make sure its moving like it should.
Old Jul 23, 2012 | 09:02 AM
farmert's Avatar
farmert
Do you have manuaL or auto locking hubs? Sounds as if one hub isn't locking. To check jack up one side of the front end, lock that hub in, and rotate the tire wile watching the u-joint in the steering nuckle. If the u-joint turns that hub is good, then check the other one the same way. If both hubs check out good, lock both hubs in with both wheels on the ground and try to turn the drive shaft. You should not be able to rotate it more than 1/16 of a turn. If that checks out, unlock the hubs, put the transfer case in 4h and the tranny in gear, try to turn the drive shaft. If it rotates something is bad in the transfer case.
Old Jul 23, 2012 | 10:09 AM
srqdiesel chef
I have auto-hubs, how do I check those?
Old Jul 23, 2012 | 10:43 AM
farmert's Avatar
farmert
I'm not to sure on the auto locking ones, but I believe you can lock them manually, you can on the auto locks on a Superduty. The Superduty ones are vaccume operated, but I have never worked on outo-locks on our trucks.
Old Jul 23, 2012 | 11:02 AM
joe f350's Avatar
joe f350
jack the front end up but the truck in gear in 4x4 and spine the tires and see if the if the drive shaft moves
Old Jul 23, 2012 | 05:24 PM
38Chevy454's Avatar
38Chevy454
Auto hubs lock by the front driveshaft putting turning force to them. With your truck parked, engine off and parking brake set for safety, get under and rotate your front driveshaft and watch the axles turn. They should turn until the hubs lock and you can no longer turn the driveshaft. They unlock by going in reverse with no 4wd. Just coasting backward like in 2wd. They will stay locked in powered reverse in 4wd.
Your transfer case in 2wd should have the front driveshaft as free and able to turn.
Old Jul 23, 2012 | 06:03 PM
bashby's Avatar
bashby
What he said. Turn the ft driveshaft in one direction a few turns while watching the ft axles. One axle will turn and you should hear it lock in as it stops and the other one starts turning. When the second one locks, you won't be able to turn the driveshaft anymore
Changing direction of rotation should unlock them but you usually have to go back and forth a couple times to unlock them. Do all this with wheels on the ground and in 2wd.
With the transfer case in4wd you shouldn't be able to turn the ft driveshaft.
Old Jul 23, 2012 | 07:31 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
those hubs were not worth a nickle when new.when these things first came out,we swapped them out asap for manual lockers.
at that time,my old man had a '95 and i a '96. this was back in '99.his,and mine both failed just inside a few yrs old.
they might be ok for those who just go over the road in a little snow from time to time or something.otherwise,don't bother trying to buy those again.get a set of manual lockers,then when you turn the dial......you know your going,rather than guessing.the worst part ever to be offered on the 9th gen trucks were those auto locking hubs.
Old Jul 24, 2012 | 08:31 AM
bashby's Avatar
bashby
I just got a set of mile markers from amazon for $150. I think you will need to buy a conversion kit also. The new hubs look like they are made well.
Old Jul 25, 2012 | 09:15 AM
srqdiesel chef
thanks for all the replies, I'm only working half day 2day so I'll spend the other half under my truck, yeeha
Old Jul 26, 2012 | 07:20 AM
srqdiesel chef
got under the truck yesterday and got out almost as fast, my son counted them for me and I have 28!! fire ant bites on my right foot. I'll work on it today after the liquid death takes effect.
Old Jul 26, 2012 | 09:56 AM
38Chevy454's Avatar
38Chevy454
Fire ants suck! Had those when I lived in San Antonio. By the time you detect them on you it is too late and those little *******s have already bitten you. 28 bites would certainly be no fun!
Old Jul 29, 2012 | 01:19 PM
srqdiesel chef
sooo, I turned the front driveshaft in 2wd and watched my axles turn, shifted into 4wd and I can't turn the drive-shaft, but when I jack up the front end I can spin the wheel with no resistance. It's the hubs, right?
Old Jul 29, 2012 | 01:45 PM
bashby's Avatar
bashby
If you turned the driveshaft the same direction for several revlutions and they didnt lock in, then yes, your hubs are bad. Get some manual ones with a conversion kit (if needed) and be done with it.
