factory paint code question
Old Jul 23, 2012 | 12:30 AM
projectdagger's Avatar
projectdagger
hello.. i've came across an 85 f-350 4x4 crew cab that is a factory two tone blue. i'd had no luck in finding the paint code for it. i was wondering if anyone know what the factory blue would had been called? thank you for your time
Old Jul 23, 2012 | 01:49 AM
FordFETruck's Avatar
FordFETruck
Look at the door jamb vin tag, it will tell you the code , it's in the bottom left it should say paint or exterior or something like that. On mine the primary color is at the far left and the secondary code is to the right of it a little bit, yours might be in a slightly different spot as they weren't always in the same spot all the time. It will be a 2 didget code though, example : 9M, 34 etc
Old Jul 23, 2012 | 08:32 AM
ctubutis's Avatar
ctubutis
Like this. If you have two-tone paint, two color codes will be listed on the same line.
Eggs2bacon
May 17, 2021 12:27 PM
beartracks
Oct 14, 2015 11:53 AM
l8000
Feb 25, 2013 04:38 AM
contento
Nov 29, 2001 09:05 PM
