rear spring bushing removal
Old Jul 22, 2012 | 10:30 AM
Hyperactive460's Avatar
Hyperactive460
ok, truck is tore down to the frame and i'm attempting to change all the bushings in the rear, needless to say it's going that easy. anyone got any suggestions ? i can't get any to turn and only managed to get one nut off.
Old Jul 22, 2012 | 03:28 PM
Canus's Avatar
Canus
Soak ALL threaded connections with Kroil, PB Blaster or other QUALITY thread penetrant and allow to sit at least overnight. Take your time, use six point sockets and everything will eventually come apart. Just finished doing this on my 74 and its not that bad.
Old Jul 22, 2012 | 03:31 PM
seththomas85's Avatar
seththomas85
+1 to Canus. I have used PB blaster on alot of hardware that has been rusted on. Let soak and life will be easier. I have applied several coats over several hours to more stubborn bolts for more peace of mind.
Old Jul 22, 2012 | 04:37 PM
dynamic's Avatar
dynamic
Flame wrench? U can heat the bolts/nuts up too. If you dont have a torch set, u can also use the little propane setups.
Old Jul 22, 2012 | 04:49 PM
Stinky7-11's Avatar
Stinky7-11
I can't speak for Kroil but I have used PB Blaster the main thing is that you use it today to make tomorrows work much easier, you will end up with fewer broken parts and knuckles. Soak everything then find something else to do or just take the rest of the day off, soak,spray it all again tonight.
Tomorrow will be a good day. no cheating
Old Jul 22, 2012 | 05:10 PM
Hyperactive460
i'll try that on the other side, i used a grinder and cut off wheel and sawzall to do the one side, still not that easy though. propane torch was working great to burn the old bushings out until the neighbors called the cops about the smell.
Old Jul 22, 2012 | 06:02 PM
dynamic's Avatar
dynamic
Your neighbors called the cops!!!!!
Man that would make me want to annoy them at every possible chance.
Old Jul 22, 2012 | 07:02 PM
1972RedNeck's Avatar
1972RedNeck
Me too
I get the nut orange and let it cool off. comes off much easier.
Old Jul 22, 2012 | 08:24 PM
hasteranger's Avatar
hasteranger
agree with whats been said. PB blaster the day before, then respray before working on it. Use a flex bar instead of a ratchet, and good 6 point sockets. Heat can help.
I don't think burning out the bushings will help you get the bolts out...
I'd get the bolts out first then work on the bushings off the truck.
Old Jul 23, 2012 | 09:33 PM
Hyperactive460
ok,, i ended up just cutting the bolts and the burning the bushings out. next problem is endless emails with the company i bought my new ones from because nothing they sent me fits. uuuuuuuuuuggggggggggghhhhhhhhhhhhh..
sent them an email tonight lets see how this works out. as far as the cops goe, they were cool. actually chatted abit about the truck itself. as for my neighbors go ...lets just say that they better have the cops on speed dial because i got a long way to go with this thing.
Old Jul 23, 2012 | 09:55 PM
hasteranger
The best kinda bushings to get, imo, are the 2 piece ones that slide in from each end. Its a captive style joint at the hangers /shackles anyway, and they are much easier to install.
Old Jul 29, 2012 | 12:27 PM
Hyperactive460
that's the kind i ordered but they don't fit. i emailed them friday afternoon, waiting to hear back from them.
Old Jul 29, 2012 | 01:41 PM
hasteranger
who did you order bushings from?? I wouldn't email, I almost always get faster/better experience picking up the phone.
wreckinball
Aug 9, 2010 09:36 PM
cajunl
May 12, 2010 10:11 PM
CatBob
Jul 23, 2008 03:33 PM
Pacerguyel2
Jul 6, 2006 08:14 PM
