Front drive only?
Old Jul 20, 2012 | 09:54 PM
GOVTMOD's Avatar
GOVTMOD
Front drive only?
Gotta quick one.
Anyone driven a bit with the front engaged only?
I have to get my rear drive line u-joints taken care of and get a new diff spindle seal. No problem getting them off but I might need to move the beast in the mean time.
I figured I could just put it into 4wd and move it using the front end only. I know I shouldn't take tight turns with the hubs locked on solid, dry ground especially with 12.5" wide tires but I was also thinking I could only lock one hub without a problem. It would only be for repositioning to get it out of the way while waiting to get the u-joints and seals done. If I needed more traction to climb my steep, and I mean steep, driveway I could lock both hubs after I pretty much had it lined up to it's desired position.
Is this a stupid idea or am I missing anything I should be aware of?
Old Jul 20, 2012 | 10:11 PM
J ballan's Avatar
J ballan
Unless you have a locker or a spool in the front locking one hub won't do anything. Lock both in, don't go to hard on it and you should be alright.
Old Jul 20, 2012 | 10:15 PM
BlueOvalDismantlers's Avatar
BlueOvalDismantlers
With an open front diff you shouldn't tear anything up with both hubs locked, I wouldnm't embark on a cross country trip but I am sure many many people have forgotten to unlock front hubs without any ill effects, so I am sure your reposition won't be a big deal. Let us know how your front wheel drive truck is.
Old Jul 20, 2012 | 10:59 PM
GOVTMOD's Avatar
GOVTMOD
****! Really? I assumed front diffs were all LS. Therefore the reason to need to lock the hubs. I guess that's why I asked the stupid question. It didn't occur to me the front diff would be open too.
Old Jul 20, 2012 | 11:13 PM
hasteranger's Avatar
hasteranger
I don't think any 70's fords came from the factory with limited slips. In fact very few trucks have in the past few decades. There are a few exceptions, but an open diff up front is pretty much the rule.
It will be very hard to turn tight but it probably won't break anything. I left my hubs locked in all the time when my truck was up int he woods at my old house.
Old Jul 21, 2012 | 04:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The only front driving axle available with optional Limited Slip (L/S) were Dana 44-9F's (3,500 lb. capacity) installed in 1978/79 F150/250's and Bronco's.
But most 44-9F's did not come with L/S unless it was ordered.
1973/77 Bronco's with the Dana 44-1 front driving axle were also available with optional L/S. But here again, most 44-1's don't have L/S unless it was ordered.
Most dealers, when they ordered these vehicles from Ford district sales offices for their inventories, did not order optional L/S as it was costly.
So, the only other way to get L/S was to order the vehicles special. This could take as long as 3 months, so most people didn't bother.
And...how would you know IF any of these vehicles have L/S as Ford usually didn't include it in the Warranty Plate AXLE code.
The ID tag is located under one of the bolts that retains the inspection cover to the housing, but many of these tags are missing today.
Old Jul 21, 2012 | 05:59 AM
OldStyle's Avatar
OldStyle
Rusty Roller
After loosing a rear universal I drove 30 miles home without any issues. I did keep her below 55 when on the freeway; just to be sure.
Old Jul 21, 2012 | 07:25 AM
Blue and White's Avatar
Blue and White
It shouldn't hurt anything with both hubs locked... just go easy on it, speed and load. Even a "limited" slip will slip enough for a turn by design.
Old Jul 21, 2012 | 08:02 AM
customrich&matt's Avatar
customrich&matt
I know this is BAD but when i was young i had a 79 blazer
running 33x12.5s and i lost my rear drive shaft and drove
it for weeks
Old Jul 21, 2012 | 07:51 PM
77 1/2 F250's Avatar
77 1/2 F250
The reason not to drive with four wheel drive engaged on hard surfaces is that it can cause binding in the transfer case when the axles turn a different radius. If you only have the front driveshaft in place, there shouldn't be any problems.
With that said, I had a 79 Bronco that a previous owner had set up (halfway) for mudding, lifted with 15.?x 38's the front was locked, the rear was open??? and it still had 3.50 gears.
When the 9 inch broke in the back, I drove it a little with the front end engaged. The locker in the front made it kind of squirrelly on pavement; point it where you wanted to go then give it gas. If you wanted to turn, you had to let of the stupid pedel.
Robert
Old Jul 24, 2012 | 06:16 PM
GOVTMOD's Avatar
GOVTMOD
Well I took off my drive line, had too cut off the clamps & didn't have a socket big enough to take off the yoke, yay! Anyway my parts guys are closed today (Utah holiday) so I had to pull the truck out.
I locked the hubs and pulled out fine. It did give a bit of a jolt as I cranked it to the right and pulled forward a bit so I could line up along the curb. Is this binding, locking up or might I just need new U-joints at my knuckles?
Old Jul 24, 2012 | 09:34 PM
77 1/2 F250
They might just need some grease. The u-joints in the front axle on my 77 dont have zerks; when I greased the front wheel bearings I was going to pull the axles to check for grease, (since I use four wheel drive a lot more than the original owner) but I couldn't get the spindles to come off. Those u-joints are probably original to the truck.
I will have to fix that one of these days.........
Thanks for the reminder,
Robert
Old Jul 24, 2012 | 10:26 PM
fellro86's Avatar
fellro86
I have done it when I blew a rear u-joint, and know of a case where they drove a Bronco for a long time with the rear diff bad, no rear drive shaft. The issue with 4x4 on dry is when both the front and rear are engaged. With just the front axle engaged, it is no different than driving a front drive car.
Old Jul 26, 2012 | 06:36 AM
GOVTMOD's Avatar
GOVTMOD
Well, if it's supposed to act like a normal fwd I've got issues. I pulled it back into the garage last night and it bucked like I was driving through a boulder field. Looks like I have at least one bad U-joint. My rear diff is making me nervous too.
Old Jul 26, 2012 | 04:23 PM
704 dentside man's Avatar
704 dentside man
I was playing in the sand a few years back in the OBX of NC...I blew the CV on the rear driveshaft in my Bronco. I either had to wait 5 days for replacement parts or drive home. I locked the fronts and made the 6 hour trip home.
As for driving through a boulder field...ujoint or balljoint(s) or both would be my guess.
