I understand that putting a good load on the engine will help keep the DPF clean. I use mine as a daily driver, and have two small hill climbs on the trip to and from work. both climbs are about a half mile, and I can run the boost up and get a decent 70mph run. My drive averages about 30-35 mph. I am about 17% idle hours.
You guys think those short blasts help, hurt or no difference.
Interesting question. I don't have a way to monitor any of it, but I've been of a similar belief - get the turbo PSI up when climbing hills. I guess it doesn't really matter. If there was a way I could see the soot build-up and EGT's it would be neat to monitor. I'm not sure that in and of itself is a good enough reason to spend more $$ though to get a meter
There is no keeping the engine healthy with DEF INJECTION sooner or later you will have problems and they aren't going to be cheep just ask the class 8 truck drivers.
The OTR drivers I know just add it to their inspection list, just another thing they have to do so they can make a living.
IMO I think towing/hauling heavey loads on fair level surface, is going to clean the DPF better than unload going up hills. the more you get on these engines(heavy acceleration) just add more soot to the DPF.
