Does a Superchips boost your boost?
Old Feb 28, 2006 | 06:23 PM
chixdigit's Avatar
chixdigit
Hey there, I have a 2004 PSD, and I was just wondering if a SCT 1704-A actually increases your boost from your turbo? If so, how much does it go to on your boost guage under hard accelleration (w/ out a trailer). I don't have a boost guage yet and I am wondering what kind of pressure increase I am running with the HP setting.
Thanks, Josh
Old Mar 1, 2006 | 09:06 AM
Lumberbrok's Avatar
Lumberbrok
on my
05' I think factory spec is like 26 pounds and when it is in High Performance it raises the speed limiter, rev limiter and turbo boost. If I am not mistaken it will max the boost out to around 34 lbs now. When I am playing around you can build the turbo up to about 30# and get on it hard when changing from 2nd-3rd gears it will jump the rpm's to around 3800 or so......you do have to be careful it will jump above max rpm's if you arent careful. I would definitely suggest keeping a sensible mind since you dont have the guages.
I may be off on the actual lbs of boost but I think this is correct
Old Mar 1, 2006 | 12:52 PM
Vic_Ferrari's Avatar
Vic_Ferrari
Remember, a boost increase is necessary for efficiency, performance, keeps smoke low AND really helps keep EGT's low.
