351 idles too fast???????
Old May 10, 2003 | 04:47 PM
Aerodude's Avatar
Aerodude
Well I got my 86 F-250 on the raod today and it runs great except it idles at around 11-1200 rpms. It is a stick and the sticker says it should be at 800. I have adjusted the timing, dash pot and back the idle screw all the way out but it still idles at 1100. Can't detect any vaccumm leaks, but when I plug off the pcv valve the idle drops. Could it be bad? The carb is a Holley 4bbl that is stock on my 351. Any suggestions?????
Old May 10, 2003 | 05:38 PM
Ford_Six's Avatar
Ford_Six
Well, try replacing the PCV valve, they are only about $2. Also check the choke linkage to make sure it isn't binding up and holding the throttle open a little.
Old May 10, 2003 | 11:36 PM
steve83's Avatar
steve83
Also, try to wiggle the throttle cross-shaft - over time, it can wear a slot into the aluminum casting, creating not only a bind, but a vacuum leak.
E350Bus
May 3, 2018 11:57 AM
chertel4
Feb 27, 2017 09:48 PM
bronco35193
General Automotive Discussion
Jun 4, 2015 11:55 PM
evansz95
Apr 16, 2014 11:29 PM
Black Ford XLT
1978 - 1996 Big Bronco
Jul 29, 2004 09:48 AM
