Sponsored by: Real Truck
A/C compressor replacement
Old Jul 19, 2012 | 07:26 PM
the beast 1's Avatar
the beast 1
I have a 01 250 superduty cc had the bearing go out and cracked the compressor housing. I replaced the compressor had the system open just lomg enough to switch compressors. Have access to vacuum pump and gauges will it be ok to just vacuum and recharge the system. thanks for the help
Old Jul 20, 2012 | 05:00 PM
mwsF250's Avatar
mwsF250
I sounds like it didn't lose any refrigerant when the housing cracked?
If you're absolutely positive:
1) there was no debris let loose in the system,
2) minimal or no oil was lost during failure and discharge
Then it should be OK.
The hard part is knowing there is the proper amount of oil. The oils that have to be used in the R134a systems is really marginal. Proper quantity is pretty critical.
If you know some was lost but not sure enough to know how much to put in, it really is worth it to flush all the old out and start with fresh quantity.
Scott Morgan
Mar 30, 2018 07:44 PM
monte97z
44
Jul 26, 2011 09:02 AM
rickfar
Escape & Escape Hybrid
Apr 15, 2011 09:18 AM
lippsenator
Jun 19, 2009 03:02 PM
ssanto
Oct 9, 2006 08:18 PM
