2001 No Start and need help
Old Jul 19, 2012 | 04:56 PM
wolffee's Avatar
wolffee
I have a 2001 that cranks and cranks. I dont think that there is any fuel being injected. I opened the fuel bowl and it was full. I do hear the fuel pump running on the rail. I cranked it while the lid to the fuel bowl was open and it was filling with fuel so fuel is getting there. Batteries are a little low now that we have been messing with getting it started but they were great when it stopped starting. Need to get some help on where to check next. I appreciate it.
Ryan
Old Jul 19, 2012 | 06:57 PM
dn29626's Avatar
dn29626
Try this. Possible bad fuel bowl heater. Disconnect your fuel bowl heater and replace the under hood fuse (i think #30) and try to start it. I cannot remember which year(s) have this issue.
Old Jul 19, 2012 | 07:29 PM
timmyboy76's Avatar
timmyboy76
also, make sure your hpop resivoir is filled to about 1/2-3/4in from plug
Old Jul 19, 2012 | 07:45 PM
c125bob's Avatar
c125bob
I agree with Tim and David. I'll add keep an eye on your battery voltage during all this cranking. If it get's below 10 volts-ish she won't start cause the injectors won't fire. Hope you get it going my friend.
Old Jul 19, 2012 | 08:33 PM
wolffee's Avatar
wolffee
Thanks guys i will give all that a try. Its my buddies truck and he says it was running fine and then just wouldnt start. Kinda weird. Truck ran great before this happened. I will let you know what we find. Thanks again
Old Jul 19, 2012 | 08:46 PM
BigAlsPSD's Avatar
BigAlsPSD
Does the tach move while cranking? What brand CPS is in it? Have you tried another CPS?
Donald Heath
Mar 25, 2019 10:50 PM
desertdogs
Aug 22, 2014 06:36 AM
mesimpson66
18
Jul 26, 2011 12:29 PM
Cinda56
Mar 24, 2008 06:43 AM
Peterson
Jan 18, 2005 08:12 PM
