BRRR, 8 Below Won't Start
Old Jan 18, 2005 | 08:52 AM
Peterson's Avatar
Peterson
We haven't been able to get the 350 Diesel started for days. It is 8 below this morning. Yes, it has been plugged in. Is there something we could put in the fuel tank, such as an additive (what about rubbing alcohol?). A friend told us it wasn't getting any fuel. We can hear the fuel pump, but it just won't start. Any ideas????
Old Jan 18, 2005 | 08:56 AM
Spaznaut's Avatar
Spaznaut
If the fuel is already gel in the fuel lines I'm not sure what ya can do besides get the truck warm. Maybe a space heater but at those temps think a heated garage is best bet. Maybe a big blower heater???
No clue on the alchol and diesel fuel.
Old Jan 18, 2005 | 09:23 AM
lancer's Avatar
lancer
Try removing the fuel filter cover. See if there is any fuel in the bowl. If not try filling it with diesel reinstall the cap and try starting it again. A good quality anti gel adative should work its way through the lines. Giver a good dose and try it again in the morning!! Let us know hoe you make out! P.S Check your batteries. Put them on charge for awhile. Low battery voltage will roll it over no probs. but the ecm won't fire the injectors under 11 volts i think it is!
Old Jan 18, 2005 | 09:30 AM
jharvey3's Avatar
jharvey3
Peterson have you looked in the fuel bowl and made sure the fuel is not gelled? If not then you need to check the maxi fuses under the hood esp #22 for the fuel heater. If it's blown then unplug the fuel heater, replace fuse and fire it up.
If the fuel has gelled then you need to get it warmed up then add some Deisel Kleen white bottle or Stanadyne DO NOT PUT ALCOHOL in it.
John
Old Jan 18, 2005 | 12:19 PM
Peterson's Avatar
Peterson
We have checked the bowl and the fuel is NOT gelled. But, we noticed there is no fuel going into the bowl, so it is not getting fuel. Any new ideas.
Old Jan 18, 2005 | 12:41 PM
Peterson's Avatar
Peterson
Also, can anyone tell me or do you have a link to a diagram where to find the FUEL PUMP RELAY??
Old Jan 18, 2005 | 04:40 PM
444dieselrod's Avatar
444dieselrod
No fuel in the bowl is a good indication that the fuel is gelled in the lines. Get some Diesel 911. they sell it at truck stops, it is an emergency antigel additive for semi's. Fill the bowl back up with good fuel, get a new filter, and add the addative, that should get you going.
What year is the truck, i am guessing since you said you can hear the pump it is a 99 or new. I have no idea where the pump relay is, but I am thinking it is good if you said you can hear the pump.
Diesel Rod
Old Jan 18, 2005 | 05:26 PM
lancer's Avatar
lancer
I agree with 444dieselrod. You also didn't mention if you checked the fuses under the hood. This was also a good suggestion. This happened to a buddies 99 3 weeks ago and his fuel heater was shorted. Blew the fuse and a no start situation. I would check those fuses if i were you. You did say the fuel pump was working earlier so i wouldn't worry about it. It is located on the frame under the truck around the driver door area. Lay under the and turn the key to the on position and see if it runs. That way you know for sure. Put the amergancy brake on for safety!! P.S I will look in my manual to see if i can find the relay for you.
Old Jan 18, 2005 | 06:41 PM
Peterson's Avatar
Peterson
Would it help if I heated around the fuel pump by the driver door????
Old Jan 18, 2005 | 06:53 PM
lancer's Avatar
lancer
You could try heating the lines with a hairdrier. It would probably ungel them if you get them warm enough. Try heating the pump good. It may suck the fuel through. Add some adative first!! That it will draw it through the lines. Keep us posted! DO NOT USE A PROPANE TORCH!! This is very dangerous!!
Old Jan 18, 2005 | 07:41 PM
Peterson's Avatar
Peterson
We have a Chiltons book, and I cannot find any mention of the fuel pump attached to the frame by the drivers door. Had it not been for you, we would have never known it was there!!
Old Jan 18, 2005 | 08:12 PM
lancer's Avatar
lancer
Glad i could help!!
mruelh
31
Mar 1, 2013 08:25 PM
heavy_d
18
Feb 22, 2013 07:24 PM
stevecavender
Jul 13, 2011 04:16 PM
signguys
46
Jan 11, 2007 07:23 AM
busakiller2001
Jan 30, 2006 06:06 AM
