If you want to just make it look better, just wipe down some of the most noticeable parts. I just use multi surface cleaner that you might use on glass and countertops and wipe off all the plastic stuff.
What do car dealers and detail shops do? You ever look at a used F150 on the lot. The engines look brand new. They have some sort of shiny film on them to.
Great suggestions from the others, but from experience working as the washboy at the auto body and mech shop you come across some pretty relentless messes.
The way i would start go to the closest you wash it and dump some quarters in it, use the engine degreaser and let it sit while you maybe wash the body (2 min or so, dont want it cooking on the motor) the come back with the pressure wash. when you get home take you air compressor and blow any standing water out of the "bowl spots". Your truck can handle as much water as rain and the tires can throw up on it. and on the trip home most of that would have evaporated or shakin out of the "bowls" anyway. Good luck and show us a picture of how it looks all cleaned up.
Yeah, and when that pressure washer shoots water down into one or more of the plug wells and the COP shorts out when you start the engine, you'll wish you hadn't.
A Steamy Jenny is not a pressure washer, it s steam cleaner. There is a difference.
Regardless, what they said above is true. They are making it look nice to sell. If it develops issues, unless you are getting a warranty its your problem.
Clean it by hand only. Real enthusiasts that do show cars clean everything by hand. They will use brushes to clean hard to reach areas, then rinse and wash the good old fashioned way.
Question, why clean your engine with anything more than a little degreased and a soapy rag unless you are entering the car in a show. An engine does not need to be clean.
They clean them to SELL them, NOT to MAINTAIN them. There is a big difference.
Makes sense...but we bought our 06' escape 3.0v6 at a local Ford dealer two years ago and the engine was spotless. Have never had an issue. Luck maybe? I would never wash the engine in my F150. How ever detail shops do it is the trick. There liable if they f-up your car.
I was not lookin' to burst anyones bubble here, but i would rather not have my experience questioned. If you are responding to the thread to help out, GREAT! And you have an opinion I have nothing against that, this is just not a place to knock other FTErs. Thanks!
All I use is a good degreaser and the hose. If you are using a power washer just don't hang out on any one component to long. You can and will force water where it doesn't need to go.
I gave some cleaning a go today on mine (mine gets shown, so there's a good cause for this...lol) and nearly ran into the COPS problem by getting a little careless with spraying. With some caution you can spray in there with a good degreaser and a hose. Be ready to do a lot of hand work though if you really want a complete finish - hose can't get everywhere.
