c6 shifter removal
Old Jul 18, 2012 | 08:28 PM
wasowski's Avatar
wasowski
c6 shifter removal
I have the 76 390 with the same year c6 and I would like to put this in a 79 super cab ,but I see that the neutral safety switch is on the shifter ,which I got from a junk yard ,so it looks like I need to remove the lever from the same transmission i got the switch off of but all the manuals I have do not say how or if it can be done ,and if not what could be my next option
thanks ahead of time and here is some eye candy
Old Jul 18, 2012 | 08:40 PM
mikeo0o0o0's Avatar
mikeo0o0o0
First, is the case you're using a '76? If it is, check to see that the case has the two bosses that are needed to mount the switch. If it does then you'll need to switch the manual gear selector, that's what Ford calls it.
1) Remove pan and drain fluid.
2) Remove nut that holds kickdown lever to shaft.
3) Remove filter and valve body.
4) Slide the kickdown shaft towards the clutch drum.
5) Snake a 7/8" box end wrench over the kickdown shaft and remove nut that retains the manual gear selector shaft.
6) Pull shaft out and remove old seal.
7) Install new seal and slide new shaft into place.
Then reassemble everything.
Probably the hardest part to the whole project is getting the valve body and shift/kickdown levers lined up.
Old Jul 18, 2012 | 09:21 PM
wasowski's Avatar
wasowski
mike to the rescue
yes the 76 does have screwholes for the switch just not the grove in the lever and lucky for me the tranny is still without fluid
I think the hardest part will be getting the yard to flip the truck over for me unless someone sells the lever
Old Jul 18, 2012 | 11:10 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The part number you need is D8TZ-7A256-A. I did a search and couldn't locate any dealers or obsolete suppliers that has any.
Old Jul 19, 2012 | 04:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by wasowski
I have the 76 390 with the same year c6 and I would like to put this in a 79 super cab.
1973/77 vs 1978/79: The shift collars are different, the NSS are different, the steering columns are different.
D5TZ-7228-A (replaced C9TZ-7228-A & C5TZ-7228-A) .. A/T Shift Collar / Available from Ford.
Applications: 1965/77 F100/350 / 1973/77 Bronco.
C7TZ-7A247-A .. NSS-Steering Column mounted (Motorcraft SW-600).
Applications: 1967/77 F100/350.
1978/79: There are two different A/T shift collars, with or without a tilt wheel / The NSS mounts on the trans, C4 is different than C6.
The TSS's are also different. There are three different types for 1973/77: A/T, M/T, 1975/77's with Speed Control.
Three different TSS for 1978/79: Tilt Wheel, A/T without tilt / M/T without tilt.
The steering wheels and the horn pads are also different.
Old Jul 19, 2012 | 04:04 PM
wasowski's Avatar
wasowski
thanks number and mike ,looks like i.m going truck flipping
82f100460
24
May 6, 2012 08:47 PM
82f100460
Feb 24, 2012 03:16 PM
daningraham
Nov 9, 2010 05:11 AM
gholland77
Jul 24, 2009 08:57 AM
William
Jan 14, 2003 12:15 AM
