possible leak
Old Jul 18, 2012 | 04:37 PM
jrank's Avatar
jrank
possible leak
Today while towing a 10ft trailer with a golf cart my truck seemed kind of under powered.It has the 5.0 with 3.73 rear end.When I got to where I was going I looked under my truck and there were spots all over the rear end and axle and frame that looked like oil or transmission fluid.I cant find any noticable leaks.Any body else ever had this happen?The air temp today was 100 and the transmission gauge stayed around 200.Thanks for any comments.
Old Jul 18, 2012 | 08:34 PM
jrank's Avatar
jrank
I crawled under the truck from front to back and cant find anything leaking.Does the transmission have some kind of relief valve if it gets hot.I wouldnt think 206 degrees is way to hot.The front side of the rear differential is covered with what looks like oil spots.
Old Jul 19, 2012 | 05:50 PM
jrank's Avatar
jrank
spots are from what looks like blowing fluid from front of vehicle.
Old Jul 19, 2012 | 07:26 PM
QwkTrip's Avatar
QwkTrip
I've never looked at my axle but in general there are only a few seals on the axle. Back cover, front pinion seal, axles ends, sensors, and the vent tube. In order to get oil stains on front of axle housing then I'd guess the front pinion seal has leaked. Take it in for warranty claim. Could be bigger problems leading to that seal failure.
Old Jul 22, 2012 | 08:29 PM
ecoboost12's Avatar
ecoboost12
Front Seal Torque Convertor
There is a past Thread from 640CI Alumium Ford that may explain your seal leak from 7/18/2012.Looks like there is no dipstick to check fluid level.
Bowstring
May 20, 2021 01:51 PM
Amaford
Aug 24, 2016 11:20 AM
Jeepers2003
Nov 14, 2010 06:52 PM
Shanemh
Feb 14, 2009 02:55 AM
1985 Ford F-150
Jul 21, 2008 03:56 PM
