Axle seal leaking ... Again
Old Nov 14, 2010 | 06:23 PM
Jeepers2003's Avatar
Jeepers2003
I replaced my rear axle bearings and seals about 3 months ago. I've put maybe 500 miles on it but today I noticed the unmistakeable dribble of gear oil on the driver side rear.
My question is this... I KNOW the seal is new. What could be causing the leak and how can I make these bearings last a while longer? I really don't want to go tearing the rear end apart...again.
Old Nov 14, 2010 | 06:40 PM
Dansww's Avatar
Dansww
You will need to clean and/or replace the breather tube that goes from the top of the axle to the frame. Also take the fitting off of the axle where the hose attaches to the axle and clean it as well. There should be a check valve on the end of the hose that will need replacing or just cleaning. This same thing happened on my 67 f250. Let me know how it goes.
Old Nov 14, 2010 | 06:52 PM
Jeepers2003
Thanks a lot. I'll take a look when the sun's up again. I'm gonna see if that's noted in the manual.
LFDavidson
16
May 3, 2011 12:07 AM
jbarefoot
Apr 6, 2011 11:45 AM
bigsam
Dec 18, 2006 02:53 PM
polcat
May 4, 2006 04:34 PM
mebush
Dec 1, 2005 10:50 PM
