I am finally getting ready to put in the 9in rear end. I am planning on removing the 3 overload leafs. Where can I find new u-bolts to mount the rearend? I do not think the stock size will work.
I'm in the middle of this on my '52. The local shops can make the "squared off" type u-bolts to order.
A couple of things I wasn't prepared for; first, the perch / pinion angle. If you use shims to correct the angle (may not be necessary on a '53), the shims are $50!! or more. And you have to replace the center bolt on the springs to make the shim part of the spring pack. Or you can move the perches, which is what I'm doing.
Also, the bottom plate is a big deal. Maybe on a '53 the springs are wider than a '52, which would be good, but I had a real hard time getting a plate that is close to the stock spring width.
As Ross pointed out unless you get lucky you will probably need to shim the axle to get the right driveline angle. The solid aluminum wedges from Summit Racing are pretty much an industry standard even used occasionally by OEMs and should be OK. The skeleton-type shown on the Speedway site are more suspect. Also I would't use multiple shims. Buy the correct degree shim. The alternative is to re-weld the spring perches in the correct position. To do either you need to start with an accurate measurement. The Kent-Moore tool for measuring driveline angle has a magnet that holds to a U-joint cap. It is a little hard to get the right angle without it. Here is one on eBay: Kent - Moore J-23498-A DRIVESHAFT INCLINOMETER.
REAR AXLE CONVERSION KIT, AXLE BELOW SPRINGS,
Converting to popular Ford 9” or any axle with a 3” housing. Includes:
Seat Pads, Tie Plates, Shock Mounts and U bolts
Requires welding shock mount to axle . . . . .2881 . . . . . . . .$89.00 kit
Same Kit With SHOCK STUDS . . . . . . . . . .2881-WSS . . .$99.00 kit
Or in parts:
U-BOLTS with high strength extra deep spring rated nuts.
Threaded extra long for use with Stock, Mono or Short Stack springs.
The Tie Plates are the ones really needed from Mid Fifty, you need the ones for a 3" axle BUT for the STOCK spring width (their catalog doesn't say anymore, so call). The stock rear spring width is 2" and the donor '70-'72 truck rear leaf spring is 2 1/2" wide. Mine looked like it was walking around a little, even though the u bolt were tight and it shaved my bump stops too.
Before pic:
Notice the shaved bumps stops on the left side and also notice how the u bolts aren't up against the leaf or the leaf seat on the side. The PO used these parts from the donor truck.
....notice how the u bolts aren't up against the leaf or the leaf seat on the side. The PO used these parts from the donor truck.
That is something I'm concerned about on mine. In the stock arrangement, the u-bolts are tight against the sides of the springs and perch to eliminate the need for spring clips for the bottom 3 or 4 leaves. Do you have any problems with the lowest leaves spinning with that gap? I was thinking of putting short sections of tubing over the u-bolts to reduce the gap.
On this truck I didn't, but had it on other cars. It could have so I wanted to fix it, the Tie Plates from Mid Fifty are drilled for a 3" tube but a 2" leaf width so the u bolts are now right back against the leaves again.
