Spark plug wires
Old Apr 20, 2009 | 05:12 PM
MYTRUCK's Avatar
MYTRUCK
Spark plug wires
I have a 1948 f6 with a 239 v8 i need to repalce the spark pluge wire dose any know if there is a stock replacemt for them - if not i need to make a custon set. Thanks for the help
Old Apr 20, 2009 | 07:18 PM
mossyoak1992's Avatar
mossyoak1992
you can get plug wires just about anywhere for that thing all the restoraiiton companies like dennis carpenter and my favorite macs atique auto parts all carry them you can also get them locally
Old Apr 20, 2009 | 07:47 PM
MYTRUCK's Avatar
MYTRUCK
The lenth of the wire are diffrent depending on the year of truck- due you know the diffrent leight needed or a match set model number to Order
Old Apr 20, 2009 | 08:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The originals had open metal terminals at the plugs, and that is about all that will pass thru the loom-brackets. The other way around that is to make your own set from stock sets, cutting one end off, passing the bare wire thru the loom first, then putting the other ends on. Kind of a PITA, but it works.
ZombieSlayer
1978 - 1996 Big Bronco
Jan 12, 2014 06:43 AM
foxbody429
Mar 15, 2013 11:43 PM
Rifle
Electrical Systems/Wiring
Jan 22, 2012 07:32 AM
berry1234
Mar 19, 2010 06:47 PM
millbobs
Mar 30, 2001 06:26 PM
