351W will not run right
Old Jul 17, 2012 | 05:57 AM
79CrewcabCummins's Avatar
79CrewcabCummins
Hi, I really need some help with this one. I have a 351W in a 79 F150 4wd with the NP435 and NP205 that I completely rebuilt with new pistons, cam, lifters, bearings, timing set, etc, etc. I can not get the hesitation out of the mid range. It is so bad that it will not rev beyond 2000rpm driving in any gear or even in neutral. I have tuned the carb(Carter AFB) repeatedly, changed the ignition components out(brain box, pickup, distributor, ign wire from switch, plugs, cap and rotor). I changed the carb to a Holly that works just fine on another 351W. I re-torqued the aluminum intake twice after running it several times in-between. I checked compression and all are 120-121 across the board. Its getting plenty of fuel(new filters and I hooked a hose to fuel pump from a 5 gallon gas can just to be sure) Its the same with or without air filter in place. I have adjusted the timing from 2* to 18* with no change in the problem. I'm at my wits end here , the next step to me seems to be to pull the intake and heads and look for something not right. Any advice or ideas would be greatly appreciated!!!
Old Jul 17, 2012 | 08:18 AM
Conanski's Avatar
Conanski
Sounds like an ignition problem, have you tried another ignition box or distributor?
Old Jul 17, 2012 | 04:37 PM
79CrewcabCummins
Conanski, I have tried 2 different DSII boxes and after that I tried an MSD 6AL box. I also tried 2 different distributors one was new withe the rebuild the other from another 351W that runs just fine.
Old Aug 2, 2012 | 05:58 PM
79CrewcabCummins
Well I found the problem, PO had some issues with the wiring it seems and the harness to the distributor had the wires cut and spliced. Only problem was 2 wires were backwards. I swapped them back orange to orange and purple to purple and all is well. The splice was covered up by loom and I didn't see it until today. I'm not sure why it made a difference or why he cut and spliced them backwards in the first place? Any ideas?
Old Aug 3, 2012 | 07:36 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
People are morons. I mean, geez, those wires are color coded. A toddler can match orange to orange.
On the plus side it kept the revs down until she was broke in real good.
Old Aug 4, 2012 | 08:37 AM
mark a.'s Avatar
mark a.
Cylinder psi seems low for a fresh engine, does it have some big cam in it or what ?
Old Aug 4, 2012 | 08:40 AM
Conanski's Avatar
Conanski
Well.. good to hear you got it fixed. How does it perform now?
Old Dec 30, 2012 | 07:30 PM
BigBlockMan's Avatar
BigBlockMan
I was going to guess you're using the wrong firing order for the 351.
ncoonen
Engine Swaps
Jun 9, 2019 05:01 PM
80ford100
Feb 3, 2015 09:13 PM
trumsey07
May 29, 2012 02:15 AM
mikeydotkom69
May 11, 2010 11:43 PM
gampas twuck
Jul 7, 2007 05:32 PM
