Sponsored by: Real Truck
ABS light
Old Jul 15, 2012 | 12:16 PM
the beast 1's Avatar
the beast 1
ABS light
have a 01 f250 superduty the abs light has been on for a couple weeks. Tried cleaning the rear sensor no help. Took the truck to AutoZone and used there tester. Partsman did not know if it would show specifics but should show the code might have to research it. The reader showed left front sensor.Low on funds so decided to tear apart and clean and check it out. Found the wire on the sensor had rubed on the tire was just about through. Spliced it back together works fine no light.The code reader sure helped instead of throwing parts at it thanks to AutoZone might help someone out there.
Old Jul 15, 2012 | 12:26 PM
cartmanea's Avatar
cartmanea
I'm surprised their scanner would read ABS codes. I had a ABS code and the local Autozone only had a generic OBDII scanner and it was no help at all.
Deagle12
Mar 24, 2018 10:21 AM
Garrthomp823
Sep 8, 2014 07:58 PM
Hunter40
Sep 10, 2012 09:49 PM
david350
1997 - 2003 F150
Nov 23, 2009 09:01 PM
1999XLT
Oct 12, 2003 01:59 AM
