Problems after truck was 'fixed'
Im guessing either way that i will need my system flushed.
I did get some readings today...
Egine cold
ICP, KOEO- I recorded around 12 the first time. after ad initial start I rechecked KOEO icp and watched psi drop from around 30 down to about 18 before cranking.
ICP during crank- 356 psi, the egine started and shot up to 899-903 psi.
the second crank was about the same- the as she idled, psi slowly droped to the 855- 830 psi range.
IPR at crank was 52.1, ad running 14.4. These readings were consistent.
Engine warm-
ICP engine idle - 630 psi
ipr 19.0-19.3%
@2500 rpm ICP 3807 psi, IPR 29.5
This happened once, after the initial acceleration, I was unable to control the throttle, the engine would rev to 3000 rpm, ad then shoot back down to 600rpm. ICP during one of these uncontrolled tests was 1302 psi.
Seems my ICP is awful low at idle. shouldnt it be around 900psi?
FICM was consistent at 48 volts. Anything else I should be checking out?
EDIT: I figured he was a 6.0 guy since thats what he drives. This is my first experience with a non dealer shop, I hate my local dealer service dept and I have always enjoyed doing things myself, but this job seemed a bit too much for me. As a side note, the truck was in the shop for 4 weeks for a 12 hr job max
Just because that's what he drives, doesn't in of itself mean he knows his way around it. He should, I can understand this assumption, but unfortunately you just never know.
Now, was he incredibly busy and backed up and that's why it took 4 wks? There really isn't any excuse after 4 wks, doing a half assed job and your having to wait at least another week until it gets fixed.
If he knows his stuff, his work ethic is seriously lacking.
Sorry, it's crap like this that gives the 6.0 the reputation that it has and it isn't deserved.
Sorry about the rant, I'll go back into my cave now.
tex I couldnt agree with you more, my friends have given me more shi... about this than I care to hear, especially my 7.3 friends
does good job with diesels. After 1 week for a 12Hr job I would of been one
very hot customer. Then being told to come back in a week.
Lets see where is my box of C-4? (not really) But I would
most likely loose my cool.
If you can I would not let the guy try to make it right. I would
get some one else to fix it and send him the bill.
Sean
How confident are you at his repair of the FICM - maybe that isn't his "expertise". I know I don't recommend anyone doing it themselves anymore - FICMRepair,com does such a good job and upgrades critical parts. It just isn't worth the risk trying to do something "precise" that you don't do every day.
If the code really is P2284, make sure your ICP sensor is properly plugged in and has no wire chaffing. Then again, that code could just be from someone trying to start it or run it with the sensor unplugged.
Remembering (or getting) the codes is the best way we can help you.
The coolant thing at this point is more a matter of principle than anything else - since you have an external oil cooler and you haven't driven it much. I would probably drain it and flush it myself instead of waiting for him to get back from vacation (but then you might just end up paying that bill when it should be him)!
Egine cold
Engine warm-
ipr 19.0-19.3%
P2284 C R Injector Control Pressure Sensor Circuit
Range/Performance
Default inferred ICP, ICP desired does not equal ICP signal,
difference of 362psi/2.5mpa.
See diagnostic manual - ICP system
P2284 Often is a HPO Flow issue or IPR or leak
Im with Mike on this IPR could be trashed
Checked the code again and it is in fact p2284. From a search i found a post from cheezit that says this code relates to the IPR not the icp.
I went ahead and rescanned the ipr and icp readings. Ill be honest, I dont think the engine was warm as in 186ect. I was looking at the dash temp guage for engine temp not my new scII. dumb.
So new readings at 186 ect, truck in park:
ICP idle- 875 ---@2500rpm 1008-1029 psi
IPR Idle- 31 ---@2500rpm 33.1
Like I said before, it is impossible to get an accurate reading @2500rpm. The truck just goes to idle or shoots to 3000 rpm when I give a little throttle. I took a video while testing Ill try to post it.
So now, at the correct temp, it seems both ipr and icp are too high?
I feel like an idiot for posting numbers when the tuck probably wasnt fully warmed up, my apologies.
Your ICP is way High for HOT Idel
Since IPR controls ICP the IPR Screen could be plugged
a plugged IPR Screen would also cause RPM Surge
IF you keep Running it the IPR is going to Blow Out
