4 speed automatic
Old May 9, 2003 | 05:37 PM
firedog's Avatar
firedog
Question 4 speed automatic
Wow what a find!
I want to use a 4 speed automatic transmission in a Jeep that I am building. Being a Ford Man I want to use a 302 that I had built up for a mustang I sold last year. I figure I can find a transmission from an Explorer that will mate with my 302(susposedly same patern as a 3.8 6 cylinder?) and the Borg Warner 1730 transfercase that came with Explorers should be fine for what I want. However I dont know jack about transmissions!! What year Explorer should I look for and am I right about the engine bolt patern? Will the trans need a computer to operate? ( I would realy like to stay away from the computers!) Thanks
Old May 9, 2003 | 09:54 PM
SDawgz's Avatar
SDawgz
4 speed automatic
Firedog, you need to check out Baumann engineerings website, www.baumannengineering.com. They have very good articles on what will fit, where and what to do to make it better. Once you choose the aod that you want, call your local vo-tech and see if they offer classes on transmission rebuilding. If they offer a class take it, it will be the best money you can spend. A rebuilt Aod can cost around $1600. The parts to rebuild an Aod will cost around $400, quite a difference. Good luck.
Old May 10, 2003 | 08:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
4 speed automatic
You are correct that the 3.8L and the 302 use the same bolt pattern.
You'll look high and low to find a 3.8L Explorer. Maybe someone installed a 3.8L somewhere, but Ford never did. Ford did build 302 Explorers from 1996-2001, though. The earliest ones were all 4x2, later ones could be either 4x2 or 4x4.
And yes, those transmissions will require a computer to operate.
Old May 12, 2003 | 08:02 AM
firedog's Avatar
firedog
4 speed automatic
Thanks for the reply Guys! I sure am glad I found thi place! It ROCKS
burnsbm0796
Sep 19, 2014 04:17 PM
burnsbm0796
Sep 18, 2014 01:34 AM
jpass2
Jan 27, 2008 03:32 PM
Silver Bronco
Dec 14, 2003 01:51 PM
335clevo
May 9, 2002 10:21 PM
